Set part number through saving with ilogic rule
hf.stork_1991
hf.stork_1991
Hello all,
Lets get right to the problem. In inventor we use a lot of structural shapes from the content center. Our problem is that the part number and file name are not the same when generating a new structural member. This leads to problems in our Bill of Materials. For instance: we never use the length in the file name because this can change a lot of times before production starts.
For this I tried to use a simple rule that runs everytime the document is saved.
iProperties.Value("Project", "Part Number") = ThisDoc.FileName
But when saving a large assembly that has a lot of updated parts and assemblies that are not checked out from the vault we get a lot of errors because these have the "read only" status. Now I wanted to try some options I found on the forum where the status of the file is used to check if a part/assembly is checked out. That way I would only run when making a new part or if it is checked out from the vault.
Dim d As Inventor.Document = ThisDoc.Document
Dim fio As New System.IO.FileInfo(d.FullDocumentName)
If fio.IsReadOnly = False Then
Else
'YOUR CODE IF THE FILE IS CHECKED NOT OUT
This is to where I got. But it still throws some errors trying to save parts/assemblies which have not been checked out. Any help would be great.
Michael.Navara
You can just test if the part number is the same as file name. In this case you can quit rule
Dim fileName As String = ThisDoc.FileName(False)
If iProperties.Value("Project", "Part Number") = fileName Then Return
