set IsContentMember to False
Hey,
How i cant set this Member
oDocPart.ComponentDefinition.IsContentMember
to False ?
with this Code as Example i can Handle it with Property but this dosent set the "isContentMember" to False
so some Software indicate it also then as Content Center Part!
if PartComponentDefinition.IsContentMember = true then
     oDocPart.DisabledCommandTypes = 0
     oDocPart.SubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}"
     On Error Resume Next
     oDocPart.PropertySets.Item("Content Library Component Properties").Delete
     Dim DTPropSet As PropertySet
     Set DTPropSet = oDocPart.PropertySets.Item("Design Tracking Properties")
     DTPropSet.Item("Catalog Web Link").Value = ""
end if
thx for Help
Mario
Hi Mario,
You are trying to set the isContentMember to false, but you set the subtype to a catalogproxy object...
From my understanding of what you want to do, try that change :
     oDocPart.SubType = "{9C88D3AF-C3EB-11D3-B79E-0060B0F159EF}"
end if
Hey,
thx for Help but this dosent work
the Property IsContentMember = true is always on true
i take also the subtype from a new ipt Document but this also dosent change
the Property
Mario
Balaji_Ram
Hi Mario,
You may need to delete another property set that Content Center parts have.
Please try deleting the 5 th and 6 th property sets as mentioned in this blog post and update the document.
http://adndevblog.typepad.com/manufacturing/2012/06/determine-whether-a-part-is-a-content-center-par...
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
The complete working Solution is very Easy
when How to know its Work Smiley Wink
ContentCenter Part convert to CustomPart
    Debug.Print oDocPart.ComponentDefinition.IsContentMember
        Call oDocPart.PropertySets.Item(6).Delete
        Call oDocPart.PropertySets.Item(5).Delete
batuhanozmen98
Hello Can you share all code for translating standard content member to custom
