Set iPart table options with iLogic?
jake_egley
jake_egley
I'd like to use iLogic to change the iPart options to index 3 digits and "Set to Member Part Number" since all my companies part numbers have three digits at the end. Is there a way to do this? Thanks
Jake Egley
Inventor 2022
Andrii_Humeniuk
Hi @jake_egley . You can change this using the FactoryOptions object. Example iLogic code:
Dim oPDoc As PartDocument = TryCast(ThisDoc.Document, PartDocument)
If oPDoc Is Nothing Then Exit Sub
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
If Not oPDef.IsiPartFactory Then Exit Sub
With oPDef.iPartFactory.FactoryOptions
	.PartNumberIndexDigits = 3
	.MemberNameType = kPartNumberMemberNameType
	.ApplyToAllMembers()
End With
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
jake_egley
Thanks @Andrii_Humeniuk . Follow up, how do I use this to show the table at the end of the rule? Also is there a way to add the description column to the table with iLogic?
Jake Egley
Inventor 2022
Andrii_Humeniuk
Honestly I don't know what to do with this, but I think the following code does everything you need. Opening the table executes the last line of code.
AddReference "Microsoft.Office.Interop.Excel"
Imports Microsoft.Office.Interop.Excel
Dim oiPart As iPartFactory
If oPDef.IsiPartFactory Then : oiPart = oPDef.iPartFactory
Else : oiPart = oPDef.CreateFactory
With oiPart.ExcelWorkSheet
	.Cells(1, .UsedRange.Columns.Count + 1).Value = "Description [Project]"
	With .Parent  : .Save() : .Close(False) : End With
End With
With oiPart.FactoryOptions
End With
ThisApplication.CommandManager.ControlDefinitions("AppCreateiPartCmd").Execute()
