Set Inventor Model State Edit Factory Scope as default
joanromero2F9DN
Message 1 of 8
joanromero2F9DN
I'm in a project related to different model states, this project will be edited by many people and I don't want it to create troubles.
The ipt that I'm creating has 3 model states which must be always related (having the Edit Factory Scope active). I've been looking everywhere and I haven't found the way to set that, every time you run the rule, the edit factory scope gets activated.
In case that this is not possible, I would like to create a msgbox with a notification every time the Edit Member Scope gets activated.
Thank you,
Replies (7)
Message 2 of 8
Frederick_Law
In factory scope, when user edit Part Number, all member will have same Part Number.
Same when user change a dimension.
Message 3 of 8
joanromero2F9DN
I provably haven't explained correctly, my question is how can I make to always set the "Edit Factory Scope" when executing a rule using iLogic.
Message 4 of 8
Frederick_Law
Ok, that make more sense.
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-BAFCA92B-9EBE-4BEE-AB1D-E09E2A4158C5
ModelStates.MemberEditScope = kEditAllMembers
ModelStates.MemberEditScope = kEditActiveMember
Message 5 of 8
joanromero2F9DN
Nice, now I have a problem which is an error that says that "ModelStates" is not declared. Do you know how to fix it?
Thank you so much for your help.
Message 6 of 8
WCrihfield
Hi @joanromero2F9DN.  You can't just use those two lines of code directly in a rule.  You have to get to the ModelStates object of the document first, then set the value of the MemberEditScope property of that ModelStates object.  The ModelStates object is located under the ComponentDefinition (PartComponentDefinition.ModelStates or AssemblyComponentDefinition.ModelStates), and the ComponentDefinition is located under the PartDocument or AssemblyDocument objects.  But if your rules are very simple, and only use simple iLogic shortcut snippets, you may be able to simply use this one line of code to fix the issue:
iLogicVb.MemberEditScope = MemberEditScopeEnum.kEditAllMembers
That line will effect how the iLogic snippets like Parameter(), iProperties.Value(), Component.IsActive(), and similar lines of code will behave.
Wesley Crihfield
(Not an Autodesk Employee)
Message 7 of 8
joanromero2F9DN
I understand that I should define the "MemberEditScope" and the "MemberEditScopeEnum" before this code but I'm not experienced in ilogic and I don't know how to do so.
Thank you for your help
Message 8 of 8
WCrihfield
Hi @joanromero2F9DN.  Here is a simple iLogic rule that only contains some starter code right now.  It first makes sure that we are working with a Part type document (not an assembly or drawing).  Then it makes sure we are working with the 'factory' document, if one exists.  There will only be a factory document when there are at least 2 ModelStates (the original one, plus at least one more).  When a there is a factory document, that is the only one that is Read/Write, while the ModelState 'member' documents will be ReadOnly.  The factory document is simply the document referenced by the 'active' ModelState.  Then it gets the ModelStates object within the part.  Then it sets the MemberEditScope to the 'All Members' variation.  The all members variation is the same as the factory scope.  After that point, you should be able to fill in the rest of your code past that point, but before the End Sub key phrase.
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then
		MsgBox("A Part Document must be active for this rule to work. Exiting.", vbCritical, "")
		Exit Sub
	Dim oPDoc As PartDocument = ThisDoc.FactoryDocument
	Dim oMSs As ModelStates = oPDoc.ComponentDefinition.ModelStates
	oMSs.MemberEditScope = MemberEditScopeEnum.kEditAllMembers
	'the rest of your code below this point, but before End Sub
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
