Set Document from IPT that is open already
inulobo
inulobo
 Set oModel = ThisApplication.Documents.Open("C:\temp\SheetMetal.ipt", False)
How do I avoid adding a direct link to the part file? I already have the part I want to work with open. How do I set that?
FINET_Laurent
Evening,
This might be a start ?
Dim oDoc As Document
For Each oDoc In ThisApplication.Documents.VisibleDocuments
	If oDoc.DisplayName = "Part.ipt"
		oDoc.Activate
Next
FINET L.
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
inulobo
Yup that's what I did. It was a pain. For some reason, it didn't work initially. Now I run a check to see if it's a part type document. Thanks for the reply.
