Set different colour for each component of Assembly based on the PN.
aurel_e
aurel_e
Hi
I have found an Ilogic from Clint Brown website:
https://clintbrown.co.uk/2019/05/04/ilogic-set-every-part-to-a-different-colour/
I would like to have the same thing (random colors) but the same color for the same part or subassy in order to distinguish the components with the same Part Number.
Would it be possible?
Thank you.
JelteDeJong
try this iLogic rule:
Dim topAsm As AssemblyDocument = ThisDoc.Document
Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(topAsm, "Unique Colors")
Dim ucRep As DesignViewRepresentation
Try
    ucRep = topAsm.ComponentDefinition.RepresentationsManager.DesignViewRepresentations("Unique Colors")
Catch ex As Exception
    ucRep = topAsm.ComponentDefinition.RepresentationsManager.DesignViewRepresentations.Add("Unique Colors")
End Try
ucRep.Activate()
Dim knowOcc As Dictionary(Of String, Asset) = New Dictionary(Of String, Asset)
Dim compOcc As ComponentOccurrence
For Each compOcc In topAsm.ComponentDefinition.Occurrences
    Dim occName As String = compOcc.ReferencedFileDescriptor.FullFileName
    If (knowOcc.ContainsKey(occName)) Then
        compOcc.Appearance = knowOcc.Item(occName)
    Else
        Dim uAppearance As Asset = topAsm.Assets.Add(AssetTypeEnum.kAssetTypeAppearance, "Generic", "appearances")
        Dim uColor As ColorAssetValue = uAppearance.Item("generic_diffuse")
        Dim RNG = Math.Round(Rnd() * 255)
        Dim RNG1 = Math.Round(Rnd() * 255)
        Dim RNG2 = Math.Round(Rnd() * 255)
        uColor.Value = ThisApplication.TransientObjects.CreateColor(RNG, RNG1, RNG2)
        compOcc.Appearance = uAppearance
        knowOcc.Add(occName, uAppearance)
Next
trans.End()
Jelte de Jong
Blog: hjalte.nl - github.com
johnsonshiue
Hi! If the color is assigned in the part (ipt) or subassembly (iam) file, the color should be on a per PN basis.
Many thanks!
Software Test Engineer
JelteDeJong
@johnsonshiue  i missed the part about the partnumber but here is the code based on the part number.
Try
End Try
ucRep.Activate()
    Dim occDoc As Document = compOcc.Definition.Document
    Dim occPropSet As PropertySet = occDoc.PropertySets.Item("Design Tracking Properties")
    Dim propert As [Property] = occPropSet.Item("Part Number")
    Dim occName As String = propert.Value
    Else
Next
trans.End()
Jelte de Jong
aurel_e
Thank you very much @JelteDeJong
It does what I asked, even when the Part Number is overwritten manually.
I wonder if it would be possible to change it to have the choice between setting a unique color to all the subassies or the single parts.
Before asking to this forum I was trying to change a rule that uses the BOM
Dim oBOMView As BOMView = oBOM.BOMViews.Item("Parts Only")
Dim oBOMRow As BOMRow
For Each oBOMRow In oBOMView.BOMRows
 I wanted to have the choice between the "Parts only" or "Structured" depending on the need.
cadEY2BL
@JelteDeJong
Is it possible to change the random RGB value to a fixed RAL color chosen from a text parameter that is in the appearance RAL library?
b.kushaiynov
it gives error on component pattern. is it possible adjust it , so that patterns have same color ?
