Set active iPart member
meck
meck
I am having a hard time figuring out how to set the active member in an iPart. Not in an assembly while I'm in the ipart factory part.
I want to loop through all of the members so the flat pattern with update then export the flat to dxf. I've got the export to dxf part, but I cannot for the life of me figure out how to activate each member. I know this should be easy, but I'm having a brain cramp I guess.
Any help would be awesome!
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
JaneFan
How about using the property to set default row in you rloop:
Code Snippet
If doc.ComponentDefinition.IsiPartFactory  Then
	Dim IPF As iPartFactory
	IPF = doc.ComponentDefinition.iPartFactory
	Dim oRow As iPartTableRow
	oRow = IPF.TableRows.Item(1)
	IPF.DefaultRow = oRow
Jane Fan
Inventor/Fusion QA Engineer
meck
Thanks JaneFan!
Here is the code...
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 8099 StartFragment: 314 EndFragment: 8067 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Public Sub LoopThruiParts
    'This sub iterates thru all of the Part of an iPart Factory
    'An iPart must be the active document
    'Set Connection to active document
    Dim oiPartDoc As PartDocument
    oiPartDoc = ThisDoc.Document
    'Check to see it it's an iPart
    If oiPartDoc.ComponentDefinition.IsiPartFactory  Then
        'Set a reference to the iPart Factory
        Dim oiPartFactory As iPartFactory
        oiPartFactory = oiPartDoc.ComponentDefinition.iPartFactory
        'Loop through all the rows in the iPart table and set that row to the active iPart
        Dim i As Integer = 0
        For i = 1 To oiPartFactory.TableRows.Count
            IPF = oiPartDoc.ComponentDefinition.iPartFactory
            oRow = IPF.TableRows.Item(i)
        Next
End Sub
Mike Eck
Using Inventor 2018
