Send Commands to Active AutoCAD Application
C_Haines_ENG
C_Haines_ENG
Is there a way to send specific commands from Inventor to an active application of AutoCAD?
Say opening the print dialogue? or changing ltscale?
C_Haines_ENG
I solved this by just reading the API on the AutoCAD forms.
ACADapp = GetObject(, "AutoCAD.Application")
ACADDoc = ACADapp.ActiveDocument
Call ACADDoc.Sendcommand("YOUR COMMAND HERE" & vbCrLf)
This program will get an open version of AutoCAD and send your command from the YOUR COMMAND LINE area.
Alternatively you can use
ACADapp = CreateObject("AutoCAD.Application")
To create a new instance of AutoCAD and send your commands there.
