SelectSet.Select method how to use?
Cris-Ideas
Advisor Advisor
Message 1 of 26
Cris-Ideas
Hi
I am trying to use Select.Set  object but I am failing to add objects to it.
Can someone advice please:
    Dim oComponentList As Inventor.SelectSet
    Dim obj As Object
        For Each obj In _invApp.ActiveDocument.SelectSet
            oComponentList.Select(obj)
            Debug.Print(obj.Name)
        Next
Works fine, but for
I an getting an error:plugin 1.png
Can someone explain me how shod I use .Select Method to add objects to Select.Set?
Cris.
Cris,
https://simply.engineering
Replies (25)
Message 21 of 26
Frederick_Law
I think, not 100% sure:
Your selectset will contain parts and sub-assemblies.  Not parts in the sub-assemblies.
When its demoted, you'll lost the object, since now its in another assembly.
When promoted, it will not be in the list since it wasn't there in the beginning.
You could go through SelectSet and add all CompOcc to your list.  Should do some test to see what happen with demote and promote.
Message 22 of 26
Cris-Ideas
@MjDeck
Thanks.
Is there any property that would allow me to find references for the same objects between sessions?
So having my object list is there any way I can save data to a file and than use it next time to grab references to exactly the same objects?
Does particular instance of object in assembly has some unique property from creation to deleting? (available through API)
Cris.
Cris,
Message 23 of 26
MjDeck
A reference key is an identifier that will be good in future sessions, as long as the object hasn't been deleted.
Another option might be to add a custom Attribute to an object.
Mike Deck
Software Developer
Autodesk, Inc.
Message 24 of 26
Cris-Ideas
If I am adding custom attribute to an object am I in fact adding this attribute to the instance of the object (so for example instance of the part) or to the part it self?
I suppose object, but would like to be sure.
What type can custom attribute be? Any? (can you point me to help reference, tried searching but not found yet).
Cris.
Cris,
Message 25 of 26
MjDeck
If you add it to a ComponentOccurrence object (which is what you get when you select a part instance in an assembly), then you're adding it to that particular instance. You can add an Attribute to anything that has an AttributeSets property. (You would generally add an AttributeSet, and then add an Attribute to the set.)
An attribute can hold a string, number, boolean, or array of bytes. An array of bytes can represent pretty much anything.
The Attribute Helper from Brian Ekins is very handy. That page also has a link to an introduction.
Mike Deck
Software Developer
Autodesk, Inc.
Message 26 of 26
Cris-Ideas
Grate suggestion with this attribute. This will save me a lot of work.
Cris.
Cris,
