SelectionFilterEnum for holes
waynehelley
waynehelley
Does anybody know if there is a SelectionFilterEnum option that will behave like the Hole creation tool.
i.e. similar to 'kPartFaceFilter' but I also need to know the co-ordinates of where the the user clicked.
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
JelteDeJong
I don't know if this is what you are looking for but the selector class lets you select a face and returns the face and the point on the face you selected. Anyway, have a look at this rule. It will create a hole in the face in the position that you clicked.
Public Class ThisRule
    Sub Main()
        Dim selector As New Selector(ThisApplication)
        selector.Pick()
        Dim doc As PartDocument = ThisDoc.Document
        Dim def As PartComponentDefinition = doc.ComponentDefinition
        Dim sketch As PlanarSketch = def.Sketches.Add(selector.SelectedFace)
        Dim point2d As Point2d = sketch.ModelToSketchSpace(selector.ModelPosition)
        Dim circleRadius = 0.5 ' in Cm!
        sketch.SketchCircles.AddByCenterRadius(point2d, circleRadius)
        Dim profile = sketch.Profiles.AddForSolid()
        Dim exturdDef = def.Features.ExtrudeFeatures.CreateExtrudeDefinition(profile, PartFeatureOperationEnum.kCutOperation)
        exturdDef.SetDistanceExtent(10, PartFeatureExtentDirectionEnum.kSymmetricExtentDirection)
        def.Features.ExtrudeFeatures.Add(exturdDef)
    End Sub
End Class
Public Class Selector
    Private WithEvents _interactEvents As InteractionEvents
    Private WithEvents _selectEvents As SelectEvents
    Private _stillSelecting As Boolean
    Private _inventor As Inventor.Application
    Public Sub New(ThisApplication As Inventor.Application)
        _inventor = ThisApplication
    End Sub
    Public Sub Pick()
        _stillSelecting = True
        _interactEvents = _inventor.CommandManager.CreateInteractionEvents
        _interactEvents.InteractionDisabled = False
        _interactEvents.StatusBarText = "Select point on face."
        _interactEvents.SetCursor(CursorTypeEnum.kCursorBuiltInCrosshair)
        _selectEvents = _interactEvents.SelectEvents
        _selectEvents.WindowSelectEnabled = False
        _interactEvents.Start()
        Do While _stillSelecting
            _inventor.UserInterfaceManager.DoEvents()
        Loop
        _interactEvents.Stop()
        _inventor.CommandManager.StopActiveCommand()
    End Sub
    Public Property SelectedFace As Object = Nothing
    Public Property ModelPosition As Point = Nothing
    Private Sub oSelectEvents_OnPreSelect(
            ByRef PreSelectEntity As Object,
            ByRef DoHighlight As Boolean,
            ByRef MorePreSelectEntities As ObjectCollection,
            SelectionDevice As SelectionDeviceEnum,
            ModelPosition As Point,
            ViewPosition As Point2d,
            View As Inventor.View) Handles _selectEvents.OnPreSelect
        DoHighlight = False
        If (not TypeOf PreSelectEntity Is Face) Then Return
        Dim face As Face = PreSelectEntity
        If (face.SurfaceType <> SurfaceTypeEnum.kPlaneSurface) Then Return
        DoHighlight = True
    End Sub
    Private Sub oInteractEvents_OnTerminate() Handles _interactEvents.OnTerminate
        _stillSelecting = False
    End Sub
    Private Sub oSelectEvents_OnSelect(
            ByVal JustSelectedEntities As ObjectsEnumerator,
            ByVal SelectionDevice As SelectionDeviceEnum,
            ByVal ModelPosition As Point,
            ByVal ViewPosition As Point2d,
            ByVal View As Inventor.View) Handles _selectEvents.OnSelect
        SelectedFace = JustSelectedEntities.Item(1)
        Me.ModelPosition = ModelPosition
    End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
dg2405
Hey Jelte,
is it possible so select an edge while beeing in an acitve sketch. Whether with the CommanManager.Pick-Method nor with your interaction-events method here it's not possible to pick an edge while beeing in an active sketch.
dg2405
I forgot to mention that this problem is only specific when selecting an edge of the same part where the sketch is acitve.
