Selection Methods
Selection Methods
tobias_wiesendanger
Selection Methods
tobias_wiesendanger
Is there a method to select what you just created?
At the moment im using an event that fires after a command stops. 2048 is the sketchedsymbol command and it should now select what the user just placed. The name of that symbol can be everything so I cant hardcode any name.
Private Sub m_userEvents_OnStopCommand(CommandID As CommandIDEnum) Handles m_userEvents.OnStopCommand
If CommandID = "2048" Then
.... Select what the user just placed ...
Kind regards
Tobias
I not 100% sure this will work.
What if you create an Object Collection then after you place the new object just select the last object in the collection.
tobias_wiesendanger
Not realy sure how I would do that. I did it know by counting symbols before and after and getting the difference to generate like .item(t) and fill the number.
Thanks for answering anyway.
