Selecting midPoint of Edges API VB.NET
florian_wenzel
Message 1 of 9
florian_wenzel
Inventor 2022
API Visual Studio
i try to create a WorkPlane AddByPlaneAndPoint.
The Tricky thing is, that i want to select the MidPoint From Edges.
I have't find this.
This is my simple Code to Create  WorkPlane AddByPlaneAndPoint.
With this Code is possible only to Select a End or Start Point.
Code:
Imports System.Runtime.InteropServices
Imports Inventor
Imports Microsoft.Win32
Module CommandFunctionButton_07
    Public Sub CommandFunctionfweButton_07()
        Dim oPartDoc As PartDocument = g_inventorApplication.ActiveDocument
        Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
        Dim oTO As TransientObjects = g_inventorApplication.TransientObjects
        Dim oTG As TransientGeometry = g_inventorApplication.TransientGeometry
        Dim oWorkPointCenter As Vertex
        oWorkPointCenter = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Pick a Points1")
        Dim oFaceTang As Face = CType(g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Pick a Face1"), Face)
        Dim oWorkPlaneCenter As WorkPlane
        oWorkPlaneCenter = oCompDef.WorkPlanes.AddByPlaneAndPoint(oFaceTang, oWorkPointCenter, False)
    End Sub
End Module
I have't find this in Object and Enums.
What is the Command for This?
Thanks for any Sugestion.
Replies (8)
Message 2 of 9
dalton98
This Worked
oWorkPointCenter = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Pick an Edge")
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
oDoc.ComponentDefinition.WorkPoints.AddByMidPoint(oWorkPointCenter)
Message 3 of 9
florian_wenzel
still dont work
Wrong Parameter
Imports Inventor
        Dim oWorkPointCenter As Edge
        oWorkPointCenter = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Pick a Edge")
        oPartDoc.ComponentDefinition.WorkPoints.AddByMidPoint(oWorkPointCenter)
        oPartDoc.Update()
        Dim oFacePlane As Face = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Pick a Face1")
        oWorkPlaneCenter = oCompDef.WorkPlanes.AddByPlaneAndPoint(oFacePlane, oWorkPointCenter, False)
    End Sub
End Module
Message 4 of 9
dalton98
Dim oPoint as WorkPoint
oPoint
= oPartDoc.ComponentDefinition.WorkPoints.AddByMidPoint(oWorkPointCenter)
oWorkPlaneCenter = oPartDoc.ComponentDefinition.WorkPlanes.AddByPlaneAndPoint(oFace, oPoint)
You need to create the midpoint as a variable.
Message 5 of 9
florian_wenzel
Still not Working:
Imports Inventor
        Dim oPoint As Inventor.Point
        oPoint = oPartDoc.ComponentDefinition.WorkPoints.AddByMidPoint(oWorkPointCenter, False)
        oPartDoc.Update()
        oWorkPlaneCenter = oCompDef.WorkPlanes.AddByPlaneAndPoint(oFacePlane, oPoint, False)
    End Sub
End Module
Error:
Object cannot converted in Inventor.Point
The Point is, but than Crash.
Message 6 of 9
dalton98
MB its dimension the point as a 'WorkPoint' not  'Inventor.Point'
Message 7 of 9
florian_wenzel
hmm, what you mean with MB?
I dont understood, sorry 🙂
I dont know, why i  must select the Edge to get the midPoint.
Manually you are able to select directly the Point.
I think, it should be also able do this with API with Automatization.
But, i very glad that you try to help me.
Message 8 of 9
dalton98
Ok I rewrote it how you had it. was saying my bad for answering sloppily.
        Dim oEdge As Edge
        oEdge = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Pick an Edge1")
		Dim oWorkPointCenter As WorkPoint
		oWorkPointCenter = oCompDef.WorkPoints.AddByMidPoint(oEdge, True)
        Dim oFaceTang As Face = CType(g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Pick a Face1"))
    End Sub
End Module
Message 9 of 9
florian_wenzel
Thanks!
its Working
