Selecting folder while exporting BOM
I have a rule for exporting BOM from my assemblies, but want to be able to select the folder in which i can save the exported excel file.
Is there a way to add a pop up window to the rule, which will let me select save folder?
Rule i am using:
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oBOM As BOM = oDoc.ComponentDefinition.BOM
oBOM.PartsOnlyViewEnabled=True
ThisBOM.Export("Parts Only", "C:\Temp\TestBOMExport.xls", FileFormatEnum.kMicrosoftExcelFormat)
m.rymut
I have something like this:
Imports System.Windows.Forms
Dim Dialog = New FolderBrowserDialog()
Dialog.SelectedPath = ExportPath
Dialog.ShowNewFolderButton = True
Dialog.Description = "Choose folder: "
If DialogResult.OK = Dialog.ShowDialog() Then
ExportPath = Dialog.SelectedPath & "\"
Else
Return
FileName = ThisDoc.FileName(False)
BOMFile = ExportPath & FileName & ".xls"
ThisBOM.Export("Parts Only", BOMFile, kMicrosoftExcelFormat)
But i think someone more experienced could do it better, mine is just a mish mash of some codes i found online and my own
A.Acheson
@m.rymut  That method looks good to open up inventor folder dialogue. It can be found as a sample in the API help also with location shown in this post.
Here is another method to pick the folder path that the assembly document is in this way you can avoid the timely folder dialogue if you save in the same location each time.
ThisDoc.Path
 And here is how to insert assembly document name as excel sheet name
 ThisDoc.PathAndFileName(False)
More info on working with document here
Regards
Alan
Thanks for reply, I wanted to have a folder dialogue every time when I export BOM, so that I could choose where to save every time.
