Selecting a Point2D with your mouse on a drawing sheet
Message 1 of 26
Hello.
How can I define a Point2D with my mouse by clicking on an random place in a drawingsheet?
I have made the code below that creates a DetailDrawingView automatic. I am now searching a method to select the oPoint & oCenterPoint with my mouse. Both are defined as Poin2D.
I find a lot a method's where you can manipulate the Point2D using maths but I never found a method where you can get the Point2D by just clicking somewhere on the sheet (drawingview).
Thanks for your help!
Sub AutoDetailedView()
' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    ' Manually select a drawing view
    Dim oDrawingView As DrawingView
    Set oDrawingView = ThisApplication.CommandManager.Pick(kDrawingViewFilter, "Select a drawing view.")
    ' Set a reference to the center of the base view.
    Dim oPoint As Point2d
    Set oPoint = oDrawingView.Center
    ' Translate point by a distance = 2 * width of the view
    ' This will be the placement point of the detail view.
    oPoint.x = oPoint.x + 2 * oDrawingView.Width
    ' Set corner one of rectangular fence as
    ' the left-bottom corner of the base view.
    Dim oCenterPoint As Point2d
    Set oCenterPoint = oDrawingView.Center
    oCenterPoint.x = oCenterPoint.x - oDrawingView.Width / 10
    oCenterPoint.Y = oCenterPoint.Y - oDrawingView.Height / 10
    ' Get any linear curve from the base view
    Dim oCurve As DrawingCurve
    For Each oCurve In oDrawingView.DrawingCurves
    If oCurve.CurveType = kLineSegmentCurve Then Exit For
    Next
    ' Create an intent object
    Dim oAttachPoint As Point2d
    Set oAttachPoint = oDrawingView.Center
    ' Create the detail view
    Dim oDetailView As DetailDrawingView
    Set oDetailView = oSheet.DrawingViews.AddDetailView(oDrawingView, oPoint, kShadedDrawingViewStyle, True, oCenterPoint, 0.3, , 0.25, False, " ")
  'Set breakline to smooth
  oDetailView.IsBreakLineSmooth = True
  'Show full detail boundary
 oDetailView.DisplayFullBoundary = True
  'Show connection line
  oDetailView.DisplayConnectionLine = True
End Sub
Replies (25)
Message 21 of 26
Nsteel
See how this works for you;
Create a new VB Class file, call it ClsSelectPoint and add the following code:
Imports Inventor
Imports System.Windows.Forms
Imports System.Runtime.InteropServices
Imports System.Configuration
Imports Microsoft.Win32
Public Class ClsSelectPoint
    Public oModelX As Double
    Public oModelY As Double
    Public oModelZ As Double
    ' Declare the event objects
    Private WithEvents oInteraction As Inventor.InteractionEvents
    Public WithEvents oMouseEvents As Inventor.MouseEvents
    Public Event MouseClick As MouseEventHandler
    ' Declare a Flag that's used to determine when selection stops.
    Private bStillSelecting As Boolean
    Private oSelectedPoint As Inventor.Point
    Public Function GetPoint() As Inventor.Point
        ' Initialize flag.
        bStillSelecting = True
        ' Create an InteractionEvents object.
        oInteraction = InvApp.CommandManager.CreateInteractionEvents
        ' Set a reference to the mouse events.
        oMouseEvents = oInteraction.MouseEvents
        ' Disable mouse move since we only need the click.
        oMouseEvents.MouseMoveEnabled = False
        oInteraction.SetCursor(CursorTypeEnum.kCursorBuiltInCrosshair)
        oInteraction.StatusBarText = "Select Point"
        ' The InteractionEvents object.
        oInteraction.Start()
        ' Loop until a selection is made.
        Do While bStillSelecting
            InvApp.UserInterfaceManager.DoEvents()
        Loop
        ' Set the return variable with the point.
        GetPoint = oSelectedPoint
        ' Stop the InteractionEvents object.
        oInteraction.Stop()
        ' Clean up.
        oInteraction.SetCursor(CursorTypeEnum.kCursorTypeDefault)
        oMouseEvents = Nothing
        oInteraction = Nothing
    End Function
    Public Sub Findpoint()
        Dim oGetPoint As New clsSelectPoint
        Dim oCP As Point2d = oGetPoint.GetPoint
    End Sub
    Private Sub oInteraction_OnTerminate()
        '    Private Sub oInteraction_OnTerminate()
        ' Set the flag to indicate we're done.
        bStillSelecting = False
    End Sub
    Public oPointX, oPointY, oPointZ As Double
    Private Sub oMouseEvents_OnMouseClick(ByVal Button As MouseButtonEnum, ByVal ShiftKeys As ShiftStateEnum, ByVal ModelPosition As Inventor.Point, ByVal ViewPosition As Point2d, ByVal View As Inventor.View) Handles oMouseEvents.OnMouseClick
        ' These are in cm
        oPointX = ModelPosition.X
        oPointY = ModelPosition.Y
        oPointZ = ModelPosition.Z
        'your code here
        MsgBox("X: " & oPointX & vbCr & "Y: " & oPointY)
    End Sub
End Class
Then use this in whichever sub you want to call ClsSelectPoint from:
        Dim oGetPoint As New ClsSelectPoint
Message 22 of 26
JhoelForshav
I saw somebody already answered what the same as me so i'll just edit this post to nothing...
Sorry about this unnecessary post
Message 23 of 26
rolandorondan
Observer
Observer
Alguien lo logro? esto trabajo en el evento _invApp.UserInterfaceManager.DoEvents()  no funciona
Message 24 of 26
PizzolatoDavide
Message 25 of 26
PizzolatoDavide
I can propose a C# solution (it should be easy to port it to VB.net).
This solution avoid busy loops and use lambda and callback function instead.
static class GetPoint
    //Prevent GC from collecting them
    public static InteractionEvents interaction;
    public static MouseEvents mouse;
    public static void getDrawingPoint(
        string prompt,
        Action<Point2d> callback,
        MouseButtonEnum button_filter = MouseButtonEnum.kLeftMouseButton)
        if(interaction != null)
            interaction.Stop();
        interaction = ThisApplication.CommandManager.CreateInteractionEvents();
        mouse = interaction.MouseEvents;
        mouse.OnMouseClick += (
            MouseButtonEnum button,
            ShiftStateEnum shiftKeys,
            Inventor.Point modelPosition,
            Point2d viewPosition,
            Inventor.View view) =>
            interaction.Stop();
            interaction = null;
            if (button == button_filter)
                Point2d position = Const.inventor.TransientGeometry.CreatePoint2d(modelPosition.X, modelPosition.Y);
                callback(position);
        interaction.StatusBarText = prompt;
        interaction.Start();
Usage:
GetPoint.getDrawingPoint("Insert table", (Point2d point) =>
    //Do something with point
Message 26 of 26
JBerns
In case someone else finds this post and wants to get a user picked point in a drawing, try this code based on examples from @xiaodong_liang posted here:
https://forums.autodesk.com/t5/inventor-programming-ilogic/using-mouse-events-using-ilogic/td-p/3795...
I expanded on Xiaodong's code to place a general note at the pick point.
See attached rule.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
