Selected Object Type
Working from the Selection (Simple) sample, how do you figure out the object type from the selected object array (oSelectedEnts)?
I've implemented the same selection mechanism in C#, but I just get an array of Objects back and have no way of determining what they are since they are returned as generic "System.__ComObject" types.
I am not sure of the syntacs in C#, but in vb.net I do something like
If typeof JustSelectedEntity(1) is some_type then
I was hoping for an easier way, but if this is the case my problem is I don't even know what objects to try a cast to.  I'm trying to select a client feature with client graphics, so how would I know what object type that would return?  So far I've tried ClientFeature and ClientFeatureDefinition and neither have worked.  I would hate to have to do this kind of guess work every time I implement selection for a different object type.
Any help with this would be appreciated.
The easiest way I have found is to set up a simple selection test in VBA and with a watch you will be able to see what type of object it is.
In C#, the watch reports a COM object type so that doesn't help.
I ended up writing my own selection mechanism and using the mouse listeners to  run it.  I needed more custom selection features for the client graphics regardless.
Thanks for the input though.
