Select?
Select?
Select?
Hi everyone.
I'm trying with the code below to show all feature dimensions, and then when i select one of them i want to display the parameter name of the dimension, but the following code only allows me to pick sketch diemsions and it´s not working for feature dimensions (ex: extrude distance), so what should i do?, Thanks.
Option Explicit
Private WithEvents oInteraction As InteractionEvents
Private WithEvents oSelect As SelectEvents
Private Sub UserForm_Initialize()
Dim i As Integer
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
Set oDef = oDoc.ComponentDefinition
Dim oSelectSet As SelectSet
Set oSelectSet = ThisApplication.ActiveDocument.SelectSet
oSelectSet.Clear
For i = 1 To oDoc.ComponentDefinition.Features.count
oSelectSet.Select oDoc.ComponentDefinition.Features(i)
Dim oControlDef As ControlDefinition
Set oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("PartShowDimensionsCtxCmd")
oControlDef.Execute
Next i
oSelectSet.Clear
' Create a new InteractionEvents object.
Set oInteraction = ThisApplication.CommandManager.CreateInteractionEvents
' Set the prompt.
oInteraction.StatusBarText = "Pick dimensions constraints from the model."
' Connect to the associated select events.
Set oSelect = oInteraction.SelectEvents
' Enable single selection.
oSelect.SingleSelectEnabled = True
' Start the selection process.
oInteraction.Start
End Sub
Private Sub oSelect_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, _
ByVal SelectionDevice As SelectionDeviceEnum, _
ByVal ModelPosition As Point, _
ByVal ViewPosition As Point2d, _
ByVal View As View)
Dim i As Long
Dim dLength As Double
Dim odim As DimensionConstraint
If JustSelectedEntities.Type = kDimensionConstraintsObject then
msgbox= odim.Parameter.Name
End Sub
The extruded distance (or angle of revolution for
Revolved features) are not going to be of type kDimensionContraintsObject.
Only the 2D sketch dimensions will fall into that category.  I don't know
what the object type of an extruded distance (or again, angle of revolution,
etc.) would be, but maybe if you remove the If statement and replace it with an
error trap, it would work.  Something like this:
On Error Goto DimError
msgbox = odim.Parameter.Name
Exit Sub
DimError:
Msgbox "Selected entity is not a
dimension."
End Sub
I haven't tried this so it's just a
theory.
Brian R.
Iwaskewycz
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">CAD Systems
Manager
href="http://www.corefurnace.com">Core Furnace Systems
I suppose you are talking about the selection not working (the display of
these dimensions works fine). Unfortunately, selection of feature dimensions
is not currently supported in the API. But, we are aware of this and there
currently is a wishlist filed for this. So, it might be provided in a future
release.
-Venkatesh Thiyagarajan.
wrote in message news:5242256@discussion.autodesk.com...
Hi everyone.
Thanks.
Option Explicit
Dim i As Integer
oSelectSet.Clear
Set oControlDef =
oControlDef.Execute
Next i
oSelectSet.Clear
Set oInteraction =
' Set the prompt.
model."
oInteraction.Start
End Sub
ByVal View As View)
Dim i As Long
End Sub
