Select rectangle
Select rectangle
Select rectangle
I use the code below to let the use select a part:
ComponentOccurrence thepartsel = (ComponentOccurrence) _inventApp.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select part");
But it only can be used to select 1 element. What I am searching for is a method to do a window selection or multiple pick.
Something like _inventApp.CommandManager.PickRectangle() 🙂
Can this be done and if so, how ?
VdVeek
Remy, In the Inventor API Help there is an example of a Window Selection example. You can find it under Sample Programs -> User Interaction -> User Interface. Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
Okay, but this example works in a part drawing. I want to selcet sketches (sketch lines) in an inventor drawing with a window select. I can't find the equivalent of "kPartEdgeCircularFilter" for sketchlines ..
VdVeek
Remy, the possible options for the selectionfilter can be found under SelectionFilterEnum Enumerator in the Api help section. When you want to select sketch items you need to search for the kSketch*** options in the Enum list. Or did you searched here already? Rob.
