Select multiple Options - Derive blocks ilogic.
Luis_Pacheco_3D
Luis_Pacheco_3D
Hi everyone. I have a rule to derive blocks of parts, but I can only select one each time I run the rule.
Imports System.IO
Class Prop
    Public Filename As String = ""
    Public Pathfile As String = ""
    Public Blockname As String = ""
End Class
Sub Main
    If ThisDoc.Document.SubType <> "{4D29B490-49B2-11D0-93C3-7E0706000000}" Then
        MessageBox.Show("No es una Pieza", "Title")
        Return
    Dim PathFolder As String = ThisApplication.FileLocations.Workspace & "\1. PREPS"
    If Not Directory.Exists(PathFolder) Then
        MessageBox.Show("La carpeta especificada no existe: " & Constants.vbCrLf & PathFolder, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Exit Sub
    Dim Listname As New ArrayList, ListFiles As List(Of Prop), oProp As Prop
    ListFiles = GetListPreps(PathFolder, Listname)
    If ListFiles.Count = 0 Then
        MessageBox.Show("Sin archivos en ruta", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Exit Sub
    Dim NombrePieza As String = GetDataInput(Listname, "Listado de archivos en la carpeta:", "Seleccione un archivo", "PREPS")
    If NombrePieza = "" Then
        MessageBox.Show("Sin selección de pieza", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Exit Sub
    oProp = ListFiles.Find(Function(x) x.Filename = NombrePieza)
    If oProp Is Nothing Then
        MessageBox.Show("No encontrado", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Exit Sub
    Listname = GetListBlocks(oProp)
    Dim ListBlockActive As List(Of Prop) = GetListDerivedActive()
    Listname = FilterArrayList(Listname, oProp, ListBlockActive)
    If Listname.Count = 0 Then
        MessageBox.Show("Sin bloques para agregar", "Información", MessageBoxButtons.OK, MessageBoxIcon.Information)
        Exit Sub
    Dim NombreBloque As String = GetDataInput(Listname, "Listado de bloques:", "Seleccione un bloque", "PREPS")
    If NombreBloque = "" Then
        MessageBox.Show("Sin selección de bloque", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Exit Sub
    GetListDerivedPartComponents(oProp, NombreBloque)
End Sub
Private Function FilterArrayList(Listname As ArrayList, oProp As Prop, ListFiles As List(Of Prop)) As ArrayList
	Dim ListResult As New ArrayList
	Dim ListFilter As List(Of Prop) = ListFiles.FindAll(Function(x) x.Filename = oProp.Filename)
	If ListFilter.Count = 0 Then
		Return Listname
	For Each str As String In Listname
		If ListFilter.Exists(Function(x) x.Blockname = Str) Then
			ListResult.Add(Str)
	Next
	Return ListResult
End Function
Private Function GetListPreps(PathFolder As String, ByRef Listname As ArrayList) As List(Of Prop)
    Dim oProp As Prop, ListFiles As New List(Of Prop)
    Listname.Clear
    ' Solicitar palabra clave para filtrar archivos
    Dim filtro As String
    filtro = InputBox("Ingrese parte del nombre del archivo a buscar (déjelo vacío para listar todos):", "Filtrar archivos", "")
    ' Obtener archivos de la carpeta
    Dim files As List(Of String) = Directory.GetFiles(PathFolder, "*.ipt", System.IO.SearchOption.TopDirectoryOnly).ToList
    ' Aplicar filtro solo si el usuario ingresó texto
    If filtro <> "" Then
        files = files.Where(Function(f) System.IO.Path.GetFileName(f).IndexOf(filtro, StringComparison.OrdinalIgnoreCase) >= 0).ToList()
    ' Si no hay archivos coincidentes, mostrar mensaje y salir
    If files.Count = 0 Then
        MessageBox.Show("No se encontraron archivos que coincidan con el filtro.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Return ListFiles
    ' Agregar archivos a la lista
    For Each File As String In files
        oProp = New Prop
        oProp.Filename = System.IO.Path.GetFileName(File)
        oProp.Pathfile = File
        Listname.Add(oProp.Filename)
        ListFiles.Add(oProp)
    Next
    Return ListFiles
End Function
Private Function GetListBlocks(oProp As Prop) As ArrayList
    Dim oPartDoc As PartDocument = ThisApplication.Documents.Open(oProp.Pathfile, False)
    For Each partblock As SketchBlockDefinition In oPartDoc.ComponentDefinition.SketchBlockDefinitions
        Listname.Add(partblock.Name)
    Next
    oPartDoc.Close(True)
    Return Listname
End Function
Private Function GetDataInput(Listname As ArrayList, mensajeparamostrar As String, defaultvalue As String, titulo As String) As String
    Dim height As Integer = 500
    If Listname.Count < 5 Then height = Listname.Count * 30
    Return InputListBox(mensajeparamostrar, Listname, defaultvalue, titulo,, height, 0)
End Function
Private Function GetListDerivedActive() As List(Of Prop)
    Dim oPartDoc As PartDocument = ThisDoc.Document, ListFiles As New List(Of Prop), oProp As Prop, oDerivedPartDef As DerivedPartUniformScaleDef
    For Each oDerPartComp As DerivedPartComponent In oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents
        oDerivedPartDef = oDerPartComp.Definition
        For Each oderv As DerivedPartEntity In oDerivedPartDef.SketchBlockDefinitions
            If Not oderv.IncludeEntity Then
                oProp = New Prop
                oProp.Filename = oDerPartComp.Name
                oProp.Blockname = oderv.ReferencedEntity.Name
        Next
    Next
    Return ListFiles
End Function
Private Sub GetListDerivedPartComponents(oProp As Prop, NombreBloque As String)
    Dim oPartDoc As PartDocument = ThisDoc.Document, status As Boolean = False
    Dim oDerivedPartDef As DerivedPartUniformScaleDef
        If oProp.Filename = oDerPartComp.Name Then
            oDerivedPartDef.SketchBlockDefinitions(NombreBloque).IncludeEntity = True
            oDerPartComp.Definition = oDerivedPartDef
            status = True
    Next
    If Not status Then
        oDerivedPartDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(oProp.Pathfile)
        oDerivedPartDef.ScaleFactor = 1
        oDerivedPartDef.ExcludeAll
        oDerivedPartDef.UseColorOverridesFromSource = False
        oDerivedPartDef.SketchBlockDefinitions.Item(NombreBloque).IncludeEntity = True
        oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(oDerivedPartDef)
    InventorVb.DocumentUpdate()
End Sub
The rule shows me the block´s list in this form.
Is it possible to select multiple options?
WCrihfield
Hi @Luis_Pacheco_3D.  That is a long, and complex code example, so I only partially read through it, but when I saw your final image and question, it made me think of something that I had posted to the forums back in mid 2023.  So, I looked that post up and will post a link to it below.  It is for a special code routine that utilizes the iLogic InputListBox in a special way, allowing for multiple selections at one time.  I hope this is what you were looking for.
https://forums.autodesk.com/t5/inventor-programming-ilogic/multiselectlistbox-based-on-ilogic-s-inpu...
Wesley Crihfield
(Not an Autodesk Employee)
Luis_Pacheco_3D
Excellent @WCrihfield works perfectly.
