Select multiple objects into part with Ilogic and I and thus be able to edit. Thanks
andrescastellanosint
Hello, I need select multiple objects into part I and thus be able to edit.
Example: Join, cut, move.
A.Acheson
@andrescastellanosint I think what you request as a workflow could be quite a complex task. What is the intention for the workflow that cannot be done manually? Can you provide more information with images etc. Are you referring to sketch geometry?
Regards
Alan
Hello, I need to select several bodies of an .ipt using a selection box as it can normally be done in an assembly, since my part has many bodies and it would be very time-consuming to do it manually
