Hello!
I've been watching for a long time a strange behavior I can not explain.
- I have a Add-In that starts a Win-Form. This form contains a button.
- When the user clicks the button, a selection is started (Select-Event as shown in the API-Sample).
- I always use the same code to handle the Select Event.
- The form is a child of Inventor [IntPtr _temp = SetWindowLong(this.Handle, GWL_HWNDPARENT, oApp.MainFrameHWND);]
After starting the Select Event objects should be prehighlighted when the mouse moves over.
Sometimes it does, sometimes I first have to click in the inventor window to see prehighlighting.
It seems to be an arbitrary behavior.
Is this a known issue?
Christoph
