select dimension drawing ilogic
h.memis
Message 1 of 11
h.memis
I want to hide the selected value and add text instead. this code changes all values. can you help me ?
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
' Clear all DrawingDimensions
For Each drawingDimension As DrawingDimension In sheet.DrawingDimensions
DrawingDimension.HideValue = True
If ((DrawingDimension.Text.FormattedText = "<DimensionValue/>") Or
(String.IsNullOrEmpty(DrawingDimension.Text.FormattedText))) Then
DrawingDimension.Text.FormattedText = ""
Next
Accepted solutions (3)
Replies (10)
Message 2 of 11
SevInventor
Hello h.memis,
such a thing?
Dim drawingDimension As DrawingDimension=ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Select a dimension")
DrawingDimension.Text.FormattedText = "example"
Message 3 of 11
h.memis
it was perfect. thank you. Finally, can it be converted to vba?
Message 4 of 11
SevInventor
I'm not shure if this works.
No time to test it:
Set DrawingDocument = ThisDoc.Document
Dim sheet As Sheet
Set sheet = doc.ActiveSheet
Set drawingDimension=ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Select a dimension")
Message 5 of 11
h.memis
the code is not working 😞 also i can't find the code in run list
Message 6 of 11
WCrihfield
You probably just have to put your code within:
Sub 'name of your macro'
.... your code here...
End Sub
(Also the Sub can not have any 'input' variables, and can not be a Function, for it to be considered a 'macro', just so you are aware.)
Edit:  And the term 'ThisDoc.Document' is an iLogic only term, so you will likely have to change that to ThisApplication.ActiveDocument, or something similar.
Wesley Crihfield
(Not an Autodesk Employee)
Message 7 of 11
h.memis
We are getting closer step by step. but there is still error 😞
Message 8 of 11
WCrihfield
Remove the "End Sub" line of code that is on about line 3.  You only need one of those at the end to close out the Sub routine.
Wesley Crihfield
Message 9 of 11
h.memis
i did what you said,sorry there is a mistake in the codes marked in red but I can't find it 😞
Message 10 of 11
WCrihfield
Sorry for all the run around.  I just created a new macro in one of my test drawings, under its DrawingProject, in a module named "OverwriteDrawingDimValue", then named my Sub within using the same name (which will be the macro's name), then typed this code into that Sub, fixed the If...Then statement, then ran it without any troubles.  Apparently VBA doesn't like the String.IsNullOrEmpty method, so I just replaced that with an empty double quote, which is usually good enough anyways.  Also got rid of most of the ( and ) marks in there, because they were not needed.  And since we are using the Pick method here, there was no need to identify a document or sheet, so I got rid of that stuff too.  Here is the resulting VBA macro that seemed to work OK for my test.
Sub OverwriteDrawingDimValue()
    Dim oDDim As drawingDimension
    Set oDDim = ThisApplication.CommandManager.Pick(kDrawingDimensionFilter, "Select a dimension.")
    oDDim.HideValue = True
    If (oDDim.Text.FormattedText = "<DimensionValue/>") Or _
        oDDim.Text.FormattedText = "" Then
        oDDim.Text.FormattedText = "example"
End Sub
Wesley Crihfield
Message 11 of 11
h.memis
you are a perfect detail 🙂 thank you
