Select Case based on 2 booleans
mat_hijs
mat_hijs
I'm trying to write a Select Case statement in iLogic that's based on 2 True/False parameters. I just tried to write it out as my human brain would process it, but who would have known computers think differently? Is there a way to do this cleanly, or am I best off just using a bunch of If/ElseIf statements?
Here's what I tried to do:
Select Case Boolean1 And Boolean2
	Case True And True
		MsgBox("True+True")
	Case True And False
		MsgBox("True+False")
	Case False And True
		MsgBox("False+True")
	Case False And False
		MsgBox("False+False")
End Select
FINET_Laurent
I whould do something like this :
Dim oString As String = Param1 & Param2
Select Case oString
Case "TrueTrue"
	MsgBox("TrueTrue")
Case "TrueFalse"
	MsgBox("TrueFalse")
Case "FalseTrue"
	MsgBox("FalseTrue")
Case "FalseFalse"
	MsgBox("FalseFalse")
End Select
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
JelteDeJong
you select statment rewritten comes down to this:
If (Boolean1 And Boolean2) = (True And True) Then
	MsgBox("True+True")
ElseIf (Boolean1 And Boolean2) = (True And False) Then
ElseIf (Boolean1 And Boolean2) = (False And True) Then
ElseIf (Boolean1 And Boolean2) = (False And False) Then
this is probably not what you wanted.  I would go for this:
If (Boolean1) Then
	If (Boolean2) Then
		MsgBox("True+True")
	Else
Else
	If (Boolean2) Then
	Else
Jelte de Jong
Blog: hjalte.nl - github.com
mat_hijs
Both these solutions would probably work perfectly, but after googling about vb.net a bit I found another solution which makes it very visual to see what's going on for a non programmer like me.
This is the solution I got:
Select Case True
	Case Boolean1 = True And Boolean2 = True
		MsgBox("True+True")
	Case Boolean1 = True And Boolean2 = False
	Case Boolean1 = False And Boolean2 = True
	Case Boolean1 = False And Boolean2 = False
End Select
Z0methink
MsgBox(Param1 & Param2)
