Select all dimensions in one view
Hubert_Los
Message 1 of 21
Hubert_Los
How to select all dimensions in one view?
Or how to check to which view the dimension belongs?
Accepted solutions (3)
Replies (20)
Message 21 of 21
FxRod
Thanks @WCrihfield , that was the method I was looking for. From your code, I only need the
Try : oCLView = DrawingDocumentUtil.GetDrawingView(cline) : Catch : End Try
and
Try : oCLView = DrawingDocumentUtil.GetDrawingView(cmark) : Catch : End Try
to get it work more or less.
But as you stated, it seems to randomly return nothing on auto-generated centerlines. Which is even more weird: When I get one single dimension from SelectSet to test, I find dimensions for which GetDrawingView returns a view, while for the same dimensions it returns nothing when used in the GetDimensionView function, although the code block I inserted is literally the same and is proven to be executed on the regarding dimension.
So, I might get back to the solution suppressing all other views, because all I want the script to do is to just count all dimensions on a selected view. The coding escalated a bit too much.
