Select all co-planar faces of a selected face in assembly
Hello Everyone,
Is there any way to select all co-planar faces of a selected face of a part in an assembly? I found a solution for the part context but still can not apply for the assembly.
Please help me in this case. Thanks in advance 🙂
Here is my code that I did try:
    Private Sub Button6_Click(sender As Object, e As EventArgs) Handles Button6.Click
        g_assemblyDoc = g_inventorApplication.ActiveDocument
        Dim _selectSet As Inventor.SelectSet
        _selectSet = g_assemblyDoc.SelectSet
        For i = 1 To _selectSet.Count
            Dim _faceProxy As Inventor.FaceProxy
            _faceProxy = _selectSet.Item(i)
            Dim _face As Inventor.Face
            _face = _faceProxy.NativeObject
            Dim _doc As Inventor.Document
            _doc = _face.Parent.ComponentDefinition.Document
            Dim _partDoc As Inventor.PartDocument
            _partDoc = g_inventorApplication.Documents.ItemByName(_doc.FullDocumentName)
            Dim params(1) As Double
            params(0) = 0.5
            params(1) = 0.5
            ' Get point on surface at param .5,.5
            Dim points(2) As Double
            Call _face.Evaluator.GetPointAtParam(params, points)
            ' Create point object
            Dim oPoint As Inventor.Point
            oPoint = g_inventorApplication.TransientGeometry.CreatePoint(points(0), points(1), points(2))
            ' Get normal at this point
            Dim normals(2) As Double
            Call _face.Evaluator.GetNormal(params, normals)
            ' Create normal vector object
            Dim oNormal As Inventor.Vector
            oNormal = g_inventorApplication.TransientGeometry.CreateVector(normals(0), normals(1), normals(2))
            Dim RefPlane As Inventor.Plane
            RefPlane = g_inventorApplication.TransientGeometry.CreatePlane(oPoint, oNormal)
            Dim bodies As Inventor.SurfaceBodies
            bodies = _partDoc.ComponentDefinition.SurfaceBodies
            Dim BodyFace As Inventor.Face
            Dim PlaneB As Inventor.Plane
            For Each Body In bodies
                For Each BodyFace In Body.faces
                    If BodyFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
                        Call BodyFace.Evaluator.GetPointAtParam(params, points)
                        PlaneB = g_inventorApplication.TransientGeometry.CreatePlane(oPoint, oNormal)
                        'Check if they are co-planar
                        If PlaneB.IsCoplanarTo(RefPlane) Then
                            Call _partDoc.SelectSet.Select(BodyFace)
                Next
            Next
        Next
    End Sub
JhoelForshav
Hi @Anonymous
I don't know if you want all coplanar faces in the same part as the selected face or in the entire assembly.
Try this rule for all coplanar faces in the entire assembly:
Sub Main
	Dim oAsm As AssemblyDocument = ThisDoc.Document
	Dim oFace As FaceProxy = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Pick face.")
	Dim oSelSet As SelectSet = oAsm.SelectSet
	For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences.AllLeafOccurrences
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject
			Dim oDef As PartComponentDefinition = oOcc.Definition
			For Each oBod As SurfaceBody In oDef.SurfaceBodies
				For Each oBodFace As Face In oBod.Faces
					If oBodFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface
						Dim oFaceProx As FaceProxy = CreateFaceProxy(oOcc.OccurrencePath, oBodFace)
						If oFaceProx.Geometry.IsCoplanarTo(oFace.Geometry) Then oSelSet.Select(oFaceProx)
				Next
			Next
	Next
End Sub
Function CreateFaceProxy(oOccList As ComponentOccurrencesEnumerator, oFace As Face) As Object
	Dim oProx As Object
	For i = oOccList.Count To 1 Step -1
		If i = oOccList.Count
			Call oOccList(i).CreateGeometryProxy(oFace, oProx)
		Else
			Call oOccList(i).CreateGeometryProxy(oProx, oProx)
	Next
	Return oProx
End Function
And this to only get the coplanar faces in the same part as the selected face:
Sub Main
	Dim oOcc As ComponentOccurrence = oFace.ContainingOccurrence
		Next
	Next
End Sub
	Dim oProx As Object
		Else
	Next
	Return oProx
End Function
Thanks, Mr. @JhoelForshav
The second case is what I need! That works so great! 🙂
