Select a sketch (which could be 2d or 3d)
DWhiteley
Advisor Advisor
DWhiteley
I would like to be able to select a sketch, which could be 2D or 3D.
Is there any way to do this?
This only works with 2D sketches, but I want to be able to select either 2D or 3D.
Dim skEnt As SketchEntity
Set skEnt = ThisApplication.CommandManager.Pick(kSketchCurveFilter, "Select sketch curve")
Thanks in advance,
Dave
envisage uk ltd
DWhiteley
Ok got it if anyone is interested:
Set oSketch = oCmdMgr.Pick(kAllEntitiesFilter, "Select source sketch (ESC)") then filter out
xiaodong_liang
Autodesk Support
Autodesk Support
As I remember, CommandManager.Pick does not support multi-filters. You would need to use InteractionEvents and SelectEvents, in which you can call SelectEventsObject.AddSelectionFilter to add multi-filters.
if you prefer to CommandManager.Pick, the way you found would be the best.
