Select a face to define as pattern orientation
blandb
Mentor Mentor
blandb
I was hoping that when using iLogic to add a pattern that I could use the Command Manager to choose a flat face to define my pattern direction like so:
Patterns.AddRectangular("RectPatternName", "component name", 3, 5 in, Nothing, ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select a flat face."), columnNaturalDirection := True)
But this gives me an error unfortunately. "Conversion from type "FaceProxy" to type string is not valid.
Reason for doing this is because I dont know the axis direction at the time of running the code and it may not be in any XYZ orientation. So choosing a face at the direction would be easier. Any thoughts?
Autodesk Certified Professional
Ralf_Krieg
Hello
First, it needs an axis at this point, not a face, to define the direction. So it would make more sense to pick a work axis or an edge. The Patterns.AddRectangular awaits the name of this workaxis or edge. For an edge, it seems you need to add a named entity to this edge first.
EDIT: Maybe something similar to this
Dim oEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeLinearFilter, "Select an edge.")
Dim iLogicAuto = iLogicVb.Automation
Dim namedEntities = iLogicAuto.GetNamedEntities(ThisDoc.Document)
namedEntities.SetName(oEdge, "MyPatternEdge")
Patterns.AddRectangular("RectPatternName", "component name", 3, 5 in, Nothing, "MyPatternEdge", columnNaturalDirection := True)
R. Krieg
RKW Solutions
www.rkw-solutions.com
blandb
thanks, I had figured out something just after I had posted this.
