Section View - inlcude slice and slice the whole part
johnster100
johnster100
I'm creating a drawing section view of a part file using the API. I would like to check the 'Include Slice' and 'Slice the Whole Part' options (shown in the menu below) suing the API. I can't find a property to do this.
Could someone help please?
thanks,
John
Sergio.D.Suárez
Hi, if you have for example two views, one is the base view, and the second the section view, you should access the property through
'Ilogic Code
Dim
oDoc As DrawingDocument oDoc = ThisDoc.Document Dim oSectionView As SectionDrawingView oSectionView = oDoc.ActiveSheet.DrawingViews.Item(2) oSectionView.IncludeSlice = True
   'VBA Code
Dim oDoc As DrawingDocument Set oDoc = ThisApplication.ActiveDocument Dim oSectionView As SectionDrawingView Set oSectionView = oDoc.ActiveSheet.DrawingViews(2)
I hope it helps you solve your problem
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
