Section Line Visibility - "DrawingSectionViewShowEntireLine.cmd"
Rich-T
Rich-T
Hi all,
I'm looking for some help with section lines in drawings.
I want a rule that selects all section lines and toggles their visibility on/off.
I can do it with
but it requires the user to select a section line - I want the code to search for and select all section lines in the IDW.
Any guidance would be greatly appreciated.
dalton98
I'm not exactly sure what you are asking but this is some code to change the drawing view style.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oView As DrawingView
For Each oView In oDoc.ActiveSheet.DrawingViews
oView = oDoc.ActiveSheet.DrawingViews.Item(1)
oView.ViewStyle = DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle
'oView.ViewStyle = DrawingViewStyleEnum.
Next
Rich-T
Thanks for your interest. What I'm after is to be able to toggle the section cut line visibility with code.
I want the code to search for all section lines in all drawing sheets, select them and toggle the visibility on/off.
I have some code that requires the user to select each section line manually but its slower than simply R-Clicking and using "Show Entire Line"
dalton98
I did a little looking around and couldn't find much. I found a way to make the entire line disapear.
Try
oView.DisplayDefinitionInBase = False
Catch
End Try
Next
 This information can be found in the top right of the inventor browser. (?) icon > Help > Programming/API Help
dalton98
@Rich-T Ok this is what you want
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
For Each oSheet In oDrawingDoc.Sheets
	For Each oView In oSheet.DrawingViews
		oDrawingDoc.SelectSet.Select(oView)
		Dim oCtrlDef As ControlDefinition
		oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingSectionViewShowEntireLineCtxCmd")
		oCtrlDef.Execute
		oDrawingDoc.SelectSet.Clear
	Next
Next
Rich-T
That's excellent, thanks Dalton.
The bit below was what I couldn't get my brain around. It all makes sense when you see it.
Thanks again.
