Searching for text within the comments for an entire directory.
shastu
Advisor Advisor
shastu
Does anyone already have something to be able to look through a directory of part files and locate all the files with certain text in the comments iProperty of the Summary tab?
WCrihfield
Here's something you can use for that.
Imports System.Windows.Forms
Dim oSFolder As String
Dim oFDialog As New FolderBrowserDialog
oFDialog.Description = "Select directory to search within."
oFDialog.RootFolder = System.Environment.SpecialFolder.MyComputer
Dim oResult As DialogResult = oFDialog.ShowDialog()
If oResult = DialogResult.OK Then
	oSFolder = oFDialog.SelectedPath
'MsgBox(oSFolder)
Dim oFileNames() As String = System.IO.Directory.GetFiles(oSFolder, "*.ipt", IO.SearchOption.TopDirectoryOnly)
Dim oFiles As New List(Of String)
Dim oPDoc As PartDocument
Dim oComments As [Property]
Dim oComment As String
For Each oFileName As String In oFileNames
	oPDoc = ThisApplication.Documents.Open(oFileName, False)
	oComments = oPDoc.PropertySets.Item("Inventor Summary Information").Item("Comments")
	oComment = oComments.Value
	If oComment.Contains("specific text") Then
		oFiles.Add(oPDoc.FullFileName)
	oPDoc.ReleaseReference
Next
ThisApplication.Documents.CloseAll(True)
a = InputListBox("Here is the list of files that contained that text within their Comments.",oFiles)
Wesley Crihfield
(Not an Autodesk Employee)
shastu
Is this something I can run in VBA?  Do I need to add a reference for it to work or what am I missing?  I should have specified that I want it to be able to be run from within Inventor VBA.
JhoelForshav
Hi @shastu
The code @WCrihfield wrote for you is iLogic 🙂
You can try this for VBA (Cred to @Lewis.Young for the VBA folder browser)
https://forums.autodesk.com/t5/inventor-customization/how-to-pick-a-folder-in-vba/td-p/8385205
Sub FindFilesWithComment()
oComment = "Hello" 'Comment to search for
Dim FolderPath As String
FolderPath = BrowseForFolder()
Dim oFSO As Object
Dim oFolder As Object
Dim oFile As Object
Dim oFiles As Object
 If FolderPath = "" Then
 Exit Sub
Dim oFileNames As String
oFileNames = "Files with comments: " & oComment
Set oFSO = CreateObject("Scripting.FileSystemObject")
Set oFolder = oFSO.GetFolder(FolderPath)
For Each oFile In oFolder.Files
  If LCase(oFSO.GetExtensionName(oFile.Name)) = "ipt" Then
  Dim oDoc As PartDocument
           Set oDoc = ThisApplication.Documents.Open(FolderPath & "\" & oFile.Name, False)
           Dim commentVal As String
           commentVal = oDoc.PropertySets.Item("Inventor Summary Information").Item("Comments").Value
           If commentVal = oComment Then
           oFileNames = oFileNames & vbCrLf & oFile.Name
           oDoc.Close
Next oFile
Call MsgBox(oFileNames, , "Found Files")
End Sub
Function BrowseForFolder(Optional OpenAt As Variant) As Variant
    Dim ShellApp As Object
    Set ShellApp = CreateObject("Shell.Application"). _
    BrowseForFolder(0, "Please choose a folder", 0, OpenAt)
    On Error Resume Next
    BrowseForFolder = ShellApp.self.Path
    On Error GoTo 0
    Set ShellApp = Nothing
    Select Case Mid(BrowseForFolder, 2, 1)
    Case Is = ":"
        If Left(BrowseForFolder, 1) = ":" Then GoTo Invalid
    Case Is = "\"
        If Not Left(BrowseForFolder, 1) = "\" Then GoTo Invalid
    Case Else
        GoTo Invalid
    End Select
    Exit Function
Invalid:
    BrowseForFolder = ""
End Function
JhoelForshav
Maybe you wanted to see if the comments contain the text, and not only find parts where the text is exactly equal to the comments:
Dim oFSO As Object
Dim oFile As Object
 Exit Sub
           If InStr(1, commentVal, oComment, vbTextCompare) > 0 Then
           oDoc.Close
Next oFile
End Sub
    On Error GoTo 0
    Case Is = ":"
    Case Is = "\"
    Case Else
        GoTo Invalid
    End Select
    Exit Function
Invalid:
End Function
WCrihfield
Wish I knew you needed VBA when I posted.  I would have offered it.  I went home for the day shortly after posting the iLogic code, so I didn't get back right away.
Here's another example of a folder browser dialog using VBA.  You may need to turn on a Reference to the Microsoft Office object library, for this to work.
Sub FolderDialog()
    Dim oFolder As Integer
    oFolder = Application.FileDialog(msoFileDialogFolderPicker).Show
    If oFolder <> 0 Then
        Call MsgBox(Application.FileDialog(msoFileDialogFolderPicker).SelectedItems(1), vbInformation, "SELECTED FOLDER")
End Sub
Sorry for the delay.
Wesley Crihfield
shastu
No problem.  That was my fault.  I should have been more specific from the beginning.  Thanks.
