Search for suppressed constraint in assembly
GeorgK
Advisor Advisor
Message 1 of 8
GeorgK
Hello Together,
how could I center the suppressed constraint? I woul like to selecet it in the listbox.
Private Sub CommandButton1_Click()
Dim oAssDoc As AssemblyDocument
Set oAssDoc = ThisApplication.ActiveDocument
Dim oConstraint As AssemblyConstraint
For Each oConstraint In oAssDoc.ComponentDefinition.Constraints
If oConstraint.HealthStatus = kSuppressedHealth Then
Call ListBox1.AddItem(oConstraint.Name)
Next oConstraint
End Sub
Thank you Georg
Replies (7)
Message 2 of 8
philippe.leefsma
Hi Georg,
What do you mean by "center the suppressed constraints"?  Do you just mean list them?
You can use the AssemblyConstraint.Suppressed property:
Sub ListConstraints()
    Dim asm As AssemblyDocument
    Set asm = ThisApplication.ActiveDocument
    Dim constraint As AssemblyConstraint
    For Each constraint In asm.ComponentDefinition.Constraints
        Debug.Print constraint.name & " Suppressed: " & constraint.Suppressed
    Next
End Sub
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
GeorgK
Hi Philippe,
I woul like to center the browser to the selected constraint and highlight it.
Thanks Georg
Message 4 of 8
philippe.leefsma
You need to find the corresponding BrowserNode in the hierarchy and set BrowserNode.Selected = True and also expand its parent.
Here is an example that will highlight and expand the constraint browser node. In your case it might be a bit more complex as it seems you want to highlight the constraint under a part occurrence node.
    Dim bp As BrowserPane
    Set bp = asm.BrowserPanes.Item("AmBrowserArrangement")
        If (constraint.Name = "Mate:1") Then
            asm.SelectSet.Select constraint
            Dim bn As BrowserNode
            Set bn = bp.GetBrowserNodeFromObject(constraint)
            Dim parent As BrowserNode
            Set parent = bn.parent
            parent.Expanded = True
    Next
End Sub
Philippe.
Philippe Leefsma
Message 5 of 8
GeorgK
I get a Run-time-error: Method "Expanded" of object "BrowserNode" failed at line "parent.Expanded = True"
Message 6 of 8
GeorgK
It works for Inventor 2014 but not for 2010.
Message 7 of 8
philippe.leefsma
2010 is an unsupported version so I can't help you on that. It might be that an issue has been fixed in between...
Philippe Leefsma
Message 8 of 8
GeorgK
This works for 2010:
  Dim oDoc As Document
        oDoc = m_invApp.ActiveDocument
        Dim oView As View
        oView = oDoc.Views.Item(1)
        Call oView.Fit()
        Dim oTopNode As BrowserNode
        Dim oNode As BrowserNode
        oTopNode = m_invApp.ActiveDocument.BrowserPanes.ActivePane.TopNode
        For Each oNode In oTopNode.BrowserNodes
            If oNode.Visible = True Then
                oNode.Expanded = True
        Next
