SCALE SKETCH BLOCK
SCALE SKETCH BLOCK
Luis_Pacheco_3D
SCALE SKETCH BLOCK
Luis_Pacheco_3D
Hello everybody, it´s possible to scale a sketch block through ilogic?
FINET_Laurent
Sure you can. Here is a small code that let you pick a sketched symbol by hand and scale it to 2 :
Dim s As Inventor.SketchedSymbol
s = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingSketchedSymbolFilter, "Pick a sketch Symbol")
s.Scale = 2
 If this solved the problem, please mark this post as solution !
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Luis_Pacheco_3D
Thanks for the response, but I refer to these types of blocks.
