Saving parameters to xml (iLogic)
I would like to save parameters marked as Key to an XML-file (from an Inventor addin, VB.NET):
        Dim addIn As ApplicationAddIn = m_inventorApp.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")   'iLogic addin
        addIn.Activate()
        Dim iLogicAddin As Object = addIn.Automation
        iLogicAddin.ParametersXmlSave(invDoc, "c:\temp\text.xml", iLogicAddin.XmlSaveOption.KeysOnly)
 This doesn't run: "Public member 'XmlSaveOption' on type 'iLogicAutomation' not found."
The documentation says:
Autodesk.iLogic.Interfaces.IiLogicAutomation.ParametersXmlSave(Inventor.Document,System.String,Autodesk.iLogic.Interfaces.XmlSaveOption)
What is the correct syntax to get the XmlSaveOption?
I've found a solution. In case others should need it:
iLogicAddin.ParametersXmlSave(invApp.ActiveDocument, Settings.XMLParameterFile,0) saves all parameters.
iLogicAddin.ParametersXmlSave(invApp.ActiveDocument, Settings.XMLParameterFile,1) saves Key marked parameters only.
