Saving new drawing using forum button as same name and location as part.
Message 1 of 9
Hi, I am having trouble writing a rule to save a drawing.  When a part is finished and a new drawing is made then finished, I would like to hit a button that saves the drawing the same as the part name/location without a window popping up.
The problem with my code is that since it is a save as, it creates a file separate to my working drawing.  I was thinking it might be possible if the code closes the active drawing and opens the 'save as' drawing. So far this is what I have:
modelFullFileName = ThisDoc.ModelDocument.FullFileName
modelDirectoryName = IO.Path.GetDirectoryName(modelFullFileName)
modelFileName = IO.Path.GetFileName(modelFullFileName)
modelFileNamewithoutextentionsion = IO.Path.GetFileNameWithoutExtension(modelFullFileName)
ThisDoc.Document.SaveAs(modelDirectoryName & "\" & modelFileNamewithoutextentionsion & ".IDW", True)
Replies (8)
Message 2 of 9
mcgyvr
All right here..
ThisApplication.ActiveDocument.save
https://forums.autodesk.com/t5/inventor-customization/help-save-not-save-as-using-ilogic/td-p/642127...
Message 3 of 9
@mcgyvr
The code you suggested would work for a drawing that has already been named and saved.  What I'm looking for is  a solution for a drawing that has not yet been initially named/saved.  The linked part would have the needed name and save location to automate this task.
Message 4 of 9
mcgyvr
@Anonymous  Did you see the link I provided?
I thought that might help you out..
You can change the true to false..
Or Open/Close as needed
oDoc = ThisDrawing.Document
DFileName = modelFileNamewithoutextentionsion & ".idw"
ThisDoc.Document.SaveAs(modelDirectoryName & "\" & DFileName, True)
ThisApplication.Documents.Open(modelDirectoryName & "\" & DFileName, True)
oDoc.Close
Message 5 of 9
Curtis_Waguespack
Hi @Anonymous
I'm not sure I completely understand your question. As written your code saves off a copy of an unsaved drawing to the same folder as the model and names it the same as the model +.idw
If you are looking to save the unsaved drawing and have it remain open, change the true to false in this line.
ThisDoc.Document.SaveAs(modelDirectoryName & "\" & modelFileNamewithoutextentionsion & ".IDW", False)
Note too that programming questions of this type are better placed on the Inventor Customization forum :
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I'll ask the moderators to move this to that forum.
I hope this helps.
Curtis
Message 6 of 9
hi @Curtis_Waguespack
Thank you for moving the forum, this is my first thread.  Adding 'FALSE' in place of 'TRUE' returned error:
Error in rule: SAVE DRAWING WITH SAME NAME AND LOCATION AS PART, in document: Partfile
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
You are correct, I am looking to save the unsaved drawing or if it has been saved already, I am looking to have it do a regular save in that case.  I assume this can be done with a simple 'IF' statement.  The problem is I cannot get the unsaved drawing to save as part name/location via form button with no windows popping up.
Message 7 of 9
Curtis_Waguespack
Hi @Anonymous
From that last error message, I think maybe your drawing file already exists on disk and is causing an error.
Below is a version of your rule with some error checking.
I hope this helps.
Curtis
If modelDirectoryName Is Nothing Then
	MessageBox.Show("modelDirectoryName is blank!", "ilogic")
	Return 'exit rule
If modelFileNamewithoutextentionsion Is Nothing Then
	MessageBox.Show("modelFileNamewithoutextentionsion is blank!", "ilogic")
	Return 'exit rule
sName = modelDirectoryName & "\" & modelFileNamewithoutextentionsion & ".IDW"
' check if the file exists
If System.IO.File.Exists(sName) Then
    MessageBox.Show("File of this name already exists!", "ilogic")
	Return 'exit rule
Try
ThisDoc.Document.SaveAs(sName, False)
Catch ex As Exception
	MessageBox.Show("Problem saving file! " & vbLf & ex.Message, "ilogic")
End Try
Message 8 of 9
Hi @mcgyvr
I did see the forum, i've been working with your code and curtis's code suggestions.
I modified the code from the forum you suggested to fit my scenario a little better.  I removed the initial question from it but I do like that it checks to see if there is a file there first.  The only issue I have now is that it doesn't close the unsaved document.  I end up with the unsaved document open and the 'saved as' document open.  I tried the 'false'/'true' edits on the save as command and it errors when I change it to false.  The close command that I tried also failed.
'Dim title As String = "converted to title case"
'    Console.WriteLine(StrConv(title, VbStrConv.ProperCase))
DrawingName = modelFileNamewithoutextentionsion
DesiredPath = modelFileName
NewFileName = DesiredPath & "\" & DrawingName & ".idw"
'check file name to see if it is used
	'if it is, ask the user to overwrite
	'if it's not, save the file
	If System.IO.File.Exists(NewFileName) Then
		question = MessageBox.Show("File exists, do you want to overwrite?", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
			If question = vbYes Then
				Dim oDrawDoc As DrawingDocument
				oDrawDoc = ThisApplication.ActiveDocument
				oDrawDoc.Save 'Modified Line 1
			Else If question =vbNo Then
				MessageBox.Show("File was not overwritten", "iLogic Message")
	Else
		ThisDoc.Document.SaveAs(NewFileName,True)
	         ThisApplication.Documents.Open(NewFileName,True)'Modified Line 2
Message 9 of 9
@Curtis_Waguespack
The code you last sent had error in saving file.  I am deleting the drawing before every new try to avoid additional errors.
