Saving image from Picturebox...
tech
tech
Hi guys I am stuck on a strange one. I get an image from the camera object using apprentice and puting it into a Picturebox. But when I try and save the image using the standard Picturebox.image.save method I get an error. Can anyone shed some light on this for me?
Private Sub Button3_Click(sender As System.Object, e As System.EventArgs) Handles Button3.Click
        Dim oApprentice As New Inventor.ApprenticeServerComponent
        Dim Doc As Inventor.ApprenticeServerDocument
        Doc = oApprentice.Open(oApp.ActiveDocument.FullFileName) 'oApp is defined elsewhere.
        ' Create a client view for the document, passing in the hWnd for a picture box.
        Dim clientView As Inventor.ClientView = Doc.ClientViews.Add(PictureBox1.Handle)
        ' Get the camera that’s associated with the client view.
        Dim cam As Inventor.Camera = clientView.Camera
        ' Define the camera.
        cam.ViewOrientationType = ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
        cam.Perspective = False
        cam.Fit()
        cam.Apply()
        clientView.Documen()
        ' Drawing the current view.
        clientView.Update(False)
        Dim oImage As Drawing.Image
        oImage = PictureBox1.Image
        oImage.Save("c:\temp\imagefile.jpg", System.Drawing.Imaging.ImageFormat.Jpeg)
    End Sub
xiaodong_liang
Autodesk Support
Autodesk Support
could you take a look if this blog helps you?
 http://modthemachine.typepad.com/my_weblog/2010/06/accessing-thumbnail-images.html
Raider_71
Hi thanks for the feedback.
Yes I know about those other methods but they still use the VB6 compatibility references. In particular: Microsoft.VisualBasic.Compatibility and STDOLE.
When creating a .Net4 project in Visual Studio it warns you that that’s obsolete. So I was hoping that there is a more current way, using ,Net 4 components and libraries, to extract the images from Inventor files.??
Awaiting your feedback
Pieter
xiaodong_liang
Autodesk Support
Autodesk Support
I see.
I forgot to recommend with the other blog
http://adndevblog.typepad.com/manufacturing/2012/07/get-thumbnail-image-by-metafile.html
Hope this helps.
Raider_71
Thanks that could help. I am trying it now but get an error " 'ThumbnailCallback' is not declared. It may be inaccessible because of its protection level"
You can download my project here: File
At the end of the day I would like to save the image to disk and also display it in the Picturebox.
xiaodong_liang
Autodesk Support
Autodesk Support
Obviously, you have not declared the function ThumbnailCallback. As you can see from that blog, a function is declared:
// callback function for GetThumbnailImageAbort
bool ThumbnailCallback()
    return false;
I believe it is not difficult for you to convert the code to VB.NET.
Please give it a try.
NachoShaw
Hi
If it helps, i could never get this to work and i was more interested in the Client View rather than the thumbnail image. Especially because i couldnt always get a thumbnail and apprentice doesnt work with an in process application. In the end, i made a rectangle to go around the picturebox and wrote a routine to take a snapshot of the contents inside the rectangle. works great for me 🙂
you can do it by using the Bitmap function
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
