Saving a .idw as a PDF with iLogic
jwesselsHZJ98
jwesselsHZJ98
I have been trying to automate the pdf creation of my .idw's through iLogic. I have looked at what seems to be just about every post on the forum, and I can't pin-point where the issue in my code is. I have attached the code and also the error that I get when the code is run.
rhasell
Hi
I copied your code, changed the directory to something that matched my system.
It worked as expected.
So is there a possibly an issue with the "M" drive?
Test the code with a local directory, and use message boxes to report the resultant directory back to you.
Reg
2026.1
jwesselsHZJ98
I removed my file path to my M drive and just used the directory path and it worked. Thanks for the help.
mmckee
I know this is an older post, but here is another variation of saving a .idw to a .pdf file. it will create a new folder in the folder that you are working on a drawing.
