So, I've changed tack a little in my pursuit of a SUFFIX.
I have found this code (below) which saves out the active sheet of the drawing out as a DXF file with the correct file name. YAY!!
'Make sure the active document is a drawing document.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("This Rule " & iLogicVb.RuleName & " only works on Drawing Documents. Exiting.", vbOKOnly + vbCritical, "WRONG DOCUMENT TYPE")
Return
'Capture the active drawing document, and its active sheet. (make sure the active sheet is the one you want to copy.)
Dim oDDoc As DrawingDocument = ThisDrawing.Document
oSheets = oDDoc.Sheets
Dim oSheet As Sheet = oDDoc.ActiveSheet
'For Each oSheet In oSheets
' oSheet.Activate
'Create the temporary drawing file, copy the sheet, then delete all sheets in new drawing.
Dim oTempDDoc As DrawingDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, , False)
Dim oTempSheet As Sheet = oSheet.CopyTo(oTempDDoc)
For Each oTSheet As Sheet In oTempDDoc.Sheets
If oTSheet IsNot oTempSheet Then
oTSheet.Delete
Next
'Get the DXF Translator AddIn
Dim oDXF_AddIn As TranslatorAddIn
For Each oAddIn As ApplicationAddIn In ThisApplication.ApplicationAddIns
If oAddIn.DisplayName = "Translator: DXF" Then
oDXF_AddIn = oAddIn
Next
Dim oTO As TransientObjects = ThisApplication.TransientObjects
Dim oContext As TranslationContext = oTO.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oOptions As NameValueMap = oTO.CreateNameValueMap
Dim oDataMedium As DataMedium = oTO.CreateDataMedium
Dim oPath As String = IO.Path.GetDirectoryName(oDDoc.FullFileName)
Dim oFName As String = IO.Path.GetFileNameWithoutExtension(ActiveSheet.Sheet.Name)
MessageBox.Show("Sheet Name - " & oFName, "Sheet Name!!")
oDataMedium.FileName = oPath & "\" & oFName & "_DXF.dxf"
MessageBox.Show("FILENAME - " & oFName, "Filename!!")
If oDXF_AddIn.HasSaveCopyAsOptions(oTempDDoc, oContext, oOptions) Then
'If your export DXF settings are saved somewhere else or named differently, you will have to change this next line.
oOptions.Value("Export_Acad_IniFile") = "C:\Users\Darren Lees\Desktop\DXF TEST\DXG-DXF\2010 DXF File.ini"
'Check to see if the DXF already exists, if it does, ask if you want to over write existing file or not.
If System.IO.File.Exists(oDataMedium.FileName) = True Then
oAnswer = MsgBox("A DXF file with this name already exists." & vbCrLf & "Do you want to over write it with this new one?", vbYesNo + vbQuestion + vbDefaultButton2, "DXF ALREADY EXISTS")
If oAnswer = vbNo Then Return
'Publish DXF
oDXF_AddIn.SaveCopyAs(oTempDDoc, oContext, oOptions, oDataMedium)
oTempDDoc.Close(True)
However, this only acts on the currently active sheet. This means I need to change to the next sheet and run the code again to get the next sheet, etc. We occasionally have drawings with 40-50+ sheets and this would get quite tedious and time consuming to continually run the rule for every sheet.
Therefore, I enclosde the relevant code inside a for-next loop in an attempt to iterate through the sheets and have it saved with the relevant title.
It didn't end well!!
I had numerous "variable 'example' hides a variable in an enclosing block" when I save/run the code.
I have a little idea about 'variable sccope', but absolutely not enough to get around this.
I don't know which way to turn, but being so close I'm hoping someone can help??.....please!!
I can supply files if required, but in this case I don't believe it'd help as I'm only focusing on the SHEET NAME for my DXF file title. Therefore, the sheet name can be changed to whatever is required.
