SaveCopyAs Error
SaveCopyAs Error
naresh_kalyan
SaveCopyAs Error
naresh_kalyan
Hi all,
My code working everything fine except the line and I attached the Error Message also. Do the VB Application needs any Reference Components. Plz... Help me
For Each referencedDoc In allReferencedDocs
' Get the full filename of the current document.
designFilename = referencedDoc.FullFileName
' Replace instances of the old design name with the new name
'newDrawingFilename = Replace(COPIPATH & ".idw", Filnam, True)
designFilename = Replace(COPIPATH & ".idw", Filnam, Filnam)
' Add the current file to the FileSaveAs object.
fileSaveAs.AddFileToSave referencedDoc, designFilename
Next
' Do the save copy as of all the files.
fileSaveAs.ExecuteSaveCopyAs
' Close the drawing.
apprenticeServer.Close
MsgBox ("Finished copying design.")
Plz, find the attachment.
Thanks in Advance.
NKalyan
naresh_kalyan
Dear all,
Here is the complete Code.
Please help me....
Public Sub Happydays()
PROJECT PARAMETERS 'GETTING ALL PARAMETERS FROM "ADODB"
Filnam = "ProjID" & lensiz & widsiz & thksiz
TEMP = App.Path & "\Temp\" & Filnam
DESPATH = BROWPATH & Filnam
Set fso = New FileSystemObject
fso.CopyFolder App.Path & "\PROJECT_FILES\ABA202030", TEMP, True
existingDesignName = "ABA202030"
newDesignName = Filnam
drawingFilenames = fso.GetFile(TEMP & "\ABA202030.idw")
Set apprenticeServer = New ApprenticeServerComponent
Set drawingDoc = apprenticeServer.Open(drawingFilenames)
Set fileSaveAs = apprenticeServer.fileSaveAs
newDrawingFilename = drawingDoc.FullFileName
newDrawingFilename = Replace(TEMP & ".idw", "ABA202030", Filnam)
fileSaveAs.AddFileToSave drawingDoc, Filnam
Set allReferencedDocs = drawingDoc.AllReferencedDocuments
designFilename = Replace(TEMP & ".idw", "ABA202030", Filnam)
'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
fileSaveAs.ExecuteSaveCopyAs ' "ERROR IS AT THIS LINE" Please refer the attachment
'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Next
End Sub
Not quite sure what the problem is. But I see some issues in the code logic.
You are closing Apprentice server within the For...Next loop. I would
suggest that you change the logic to something along the following lines:
Next
Sanjay-
wrote in message news:5525702@discussion.autodesk.com...
Dear all,
Please help me....
Next
End Sub
naresh_kalyan
Thanks for the response... but there's no change. Same Error. Once again I am typing the Error ..
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Run-time error '-2147467259(800004005)':
Method 'ExecuteSaveCopyAs' of object '_IRxFileSaveAs' failed
Do I need to load any Add-inns or Components or References..
Please... Sanjay. Please help me out.
NKalyan
naresh_kalyan
Dear Sanjay,
Thanks for ur support and I figured it out.
But, Here one more Error I am facing while running my EXE file. I have attached a jpeg file which shows the Error.
Is this a Virus or any system Problem?
Thanks again!!!
NKalyan
there was an error thrown that wasn't handled, that is what the message is essentially saying.
Try replacing the section of code giving the error with:
On Error Resume Next
fileSaveAs .ExecuteSaveCopyAs
If Err Then
MsgBox Err.Description(), vbOK, "Error"
Err.Clear
On Error Resume 0
