SaveAsBitmap method doesn't honor topColor and bottomColor arguments
psaarloos
psaarloos
The SaveAsBitmap method doesn't seem to honor the optional topColor and bottomColor arguments anymore when the Inventor background is set to 'Background Image' instead of '1 Color' or 'Gradient'. This behavior seems to have been changed since Inventor 2016. It was working correctly in Inventor 2015 and before.
Can this be reproduced and fixed? I am using this code to create a thumbnail with a white background.
Dim transientObjects As TransientObjects = _inventorApplication.TransientObjects
Dim backGroundColor As Color = transientObjects.CreateColor(255, 255, 255)
activeView.Camera.SaveAsBitmap(thumbnailFilePath, 600, 600, backGroundColor, backGroundColor)
Pim Saarloos
Product Manager
If my post answers your question, please click the "Accept as Solution" button. Kudos are much appreciated!
sajith_subramanian
Autodesk Support
Autodesk Support
Hi psaarloos,
I am able to reproduce the issue as well.
As a workaround can you try the following piece of code. It seems to work on Inventor 2017.
Sub main()
Dim transientObjects As transientObjects
Set transientObjects = ThisApplication.transientObjects
Set backGroundColor = transientObjects.CreateColor(255, 255, 255)
Dim cam As Camera
Set cam = ThisApplication.ActiveView.Camera
Dim oImage As IPictureDisp
Set oImage = ThisApplication.ActiveView.Camera.CreateImage(600, 600, backGroundColor)
stdole.SavePicture oImage, "C:\TEMP\image1.jpg"
End Sub
Please let me know if it helps.
Sajith
Sajith Subramanian
Autodesk Developer Network
