Saveas Ilogic not saving??
Can someone give me a pointer. I am using this doe I cobbled together/pinched and trying to get the filename to be (mostly) predetermined by user input on form.  Got it all working, and the saveas dialog is prepopulated with the coirrect ino...but the file is not actually saving.???
Goes through the motions but nothing is happening. Any ideas?
If ThisDoc.Path = "" Then
    'If Document has Not been saved before...
'SAVE AS DIALOG BOX
    'define the active document
    oDoc = ThisDoc.Document
    'create a file dialog box
    Dim oFileDlg As Inventor.FileDialog = Nothing
    InventorVb.Application.CreateFileDialog(oFileDlg)
    'Set dialog filter
    'oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt"
    'set the directory to open the dialog at
    'oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
    'set the file name string to use in the input box as the value entered in Excel Spreadsheet
    oFileDlg.FileName = iProperties.Value("Project","Project") & "-" & iProperties.Value("Summary","Category")& "-XXXX-" & iProperties.Value("Summary","Title")
    'work with an error created by the user backing out of the save
    oFileDlg.CancelError = True
    On Error Resume Next
    'specify the file dialog as a save dialog (rather than a open dialog)
    oFileDlg.ShowSave()
    'catch an empty string in the imput
    If Err.Number <> 0 Then
    MessageBox.Show("No File Saved.", "Save: Dialog Canceled")
    ElseIf oFileDlg.FileName <> "" Then
    'save the file
    oDoc.SaveAs(iProperties.Value("Project","Project") & "-" & iProperties.Value("Summary","Category"), False) 'True = Save As Copy & False = Save As
Else
JhoelForshav
Hi @Anonymous
You need a file-extension (ex: .ipt, .iam) to save the document.
Try this 🙂
	'SAVE AS DIALOG BOX
	Dim oDoc As Document = ThisDoc.Document
	'Set dialog filter
	oFileDlg.FileName = iProperties.Value("Project", "Project") & "-" & iProperties.Value("Summary", "Category") & "-XXXX-" & iProperties.Value("Summary", "Title")
	oFileDlg.ShowSave()
		Dim oExt As String
		If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oExt = ".iam"
		If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then oExt = ".ipt"
		If oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then oExt = ".dwg"
		oDoc.SaveAs(oFileDlg.FileName & oExt, False) 'True = Save As Copy & False = Save As
JhoelForshav
But I think it's better to use the FileDialog filter for this:
	'SAVE AS DIALOG BOX
	'Set dialog filter
	If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam"
	If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt"
	If oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then oFileDlg.Filter = "Autodesk Inventor Drawing Files (*.dwg)|*.dwg"
	oFileDlg.ShowSave()
		oDoc.SaveAs(oFileDlg.FileName, False) 'True = Save As Copy & False = Save As
Thanks. I was just tring your first solution.
I got it working as a standard rule, but wouldnt as an external rule.
Ill just try the new one now
