Save to single-sheet PDF
vickimclJRCYT
Message 1 of 21
vickimclJRCYT
I am not an ilogic programmer (yet), I am just starting to learn. I copied this code from 2 different sources but I'm having a problem with the sheet number. It's saving with a 2 in the filename, but I do not understand where it is pulling this from especially when running the rule from sheet 1, as it should be a 1 not a 2. All other properties are appearing in filename correctly, except the sheet number.
PDF filename: Project Number-Part Number-Sheet Number Description.pdf (Ex: S2100-A100-1 Tail Frame.pdf)
I know you guys are the experts, any help would be greatly appreciated. Thanks.
Here is the code:
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDescription = iProperties.Value("Project", "Description")
oPartNumber = iProperties.Value("Project", "Part Number")
oProject = iProperties.Value("Project", "PROJECT")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oDoc = ThisDoc.Document
' Define folder browse dialog
Dim Dialog = New FolderBrowserDialog()
Dialog.SelectedPath = "T:\ENG 3D\JOBS"
Dialog.ShowNewFolderButton = True
Dialog.Description = "Choose Folder for Export..."
If DialogResult.OK = Dialog.ShowDialog() Then
ExportPath = Dialog.SelectedPath & "\"
Else
Exit Sub
'Define the drawing
Dim oDrawing As DrawingDocument
oDrawing = ThisDoc.Document
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
Dim sSheetName As String
Dim iSheetNumber As Integer
'step through each drawing sheet
For Each oSheet In oDrawing.Sheets
	'find the seperator in the sheet name:number
	lPos = InStr(oSheet.Name, ":")
	'find the number of characters in the sheet name
	sLen = Len(oSheet.Name)
	'find the sheet name
	sSheetName = Left(oSheet.Name, lPos -1)
	'find the sheet number
	iSheetNumber = Right(oSheet.Name, sLen - lPos)
	Next
'set PDF Options
If oPDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
oOptions.Value("Custom_Begin_Sheet") = iSheetNumber
oOptions.Value("Custom_End_Sheet") = iSheetNumber
If iProperties.Value("Project", "Revision Number") >= "1" Then
ExportPath = ExportPath
oDataMedium.FileName = ExportPath & oProject & "-" & oPartNumber & "-" & iSheetNumber & " " & oDescription & ".pdf"
Try
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
' Ask the user if he/she wants to open the file
question2 = MessageBox.Show("Open PDF file?", "PDF Created",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
If question2 = vbYes Then
ThisDoc.Launch(oDataMedium.FileName)
Catch
MessageBox.Show("PDF not created, document may be open.", "Please close and try again ")
End Try
Exit Sub
Victoria
Replies (20)
Message 2 of 21
WCrihfield
Try getting rid of that whole block of code for getting the sheet number, and all of the variables you created for it, then replace all of that with this:
iSheetNumber = oSheet.Name.Split(":")(1)
Split splits the name into multiple parts as an Array of String, and it will be split by the ":" character, so the resulting string array results in 2 parts...sheet name, then sheet number.  Then the (1) after the Split call is returning the second of the two parts (array's are zero based, so Item(0) is its first item).
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 21
vickimclJRCYT
@WCrihfield
Thanks for the reply. I think I need a bit more help.
Should I be replacing this:
Message 4 of 21
vickimclJRCYT
I think my problem is that it is not looping all sheets. Perhaps I need to re-arrange code.
I need the dialog box in order to pick the location before save. However with more than one sheet, only one sheet is being saved. Hmm..
Message 5 of 21
WCrihfield
First of all...this is not a 'solution', just a tip of sorts.  I attempted to clean up your code a bit, but I still don't think it will function the way you are expecting, because the export process is exporting the entire document, not just a single sheet.  By the way, you had the keyword "Next" right after you got the sheet number, so that ended your loop of the sheets, instead of putting Next at the end of the code.  I moved some stuff around and eliminated a couple of other things that did not appear to be used or of any use.
Here is the cleaned up code, but as I said, it still won't export just one sheet at a time as it is...in fact, it will now likely try to export the same PDF (of the whole drawing document) as many times as there are sheets.  I doubt inputting the oSheet variable instead of the oDrawing variable as the first input variable of the SaveCopyAs method would work, even though it is defined as an 'Object', because a sheet is not a document by itself.
'Define the drawing
Dim oDrawing As DrawingDocument = ThisDoc.Document
Dim oPDFAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById _
'set PDF Options
If oPDFAddIn.HasSaveCopyAsOptions(oDrawing, oContext, oOptions) Then
Dim ExportPath As String
Else
	Exit Sub
For Each oSheet As Sheet In oDrawing.Sheets
	Try
		oPDFAddIn.SaveCopyAs(oDrawing, oContext, oOptions, oDataMedium)
	Catch
	End Try
Next
 To fix the one sheet at a time problem, I believe I have seen others copy each sheet out to another new temporary drawing document, then export that other drawing document, in order to get just that one sheet exported each time, then get rid of that other temporary drawing document when the process is done...all by code of course.  If that sounds like a plan that you would want to try, we can go from there.
Wesley Crihfield
Message 6 of 21
WCrihfield
I went ahead and altered your code a bit more to explore the last idea I mentioned at the end of my last post, about copying each sheet over to a new temporary drawing, then exporting that other drawing.  I haven't tested it yet, because the file naming convention would not work for me, but you can try it out.  If you want, you could also specify the full file name of the drawing template file you want the other temporary drawing file to be created from, as the second input variable of the Documents.Add() method I'm using to create that other drawing.  Since that input variable is optional, and I don't know the path or name of your template, I just left it out or now.
'Define the drawing
'set PDF Options
Else
	Exit Sub
	Dim oNewTempDrawing As DrawingDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject)
	'copy our sheet to the other drawing
	oOtherCopiedSheet = oSheet.CopyTo(oNewTempDrawing)
	'get rid of the default first sheet from that other drawing, leaving just our copied sheet
	oNewTempDrawing.Sheets.Item(1).Delete(False)
	Try
		oPDFAddIn.SaveCopyAs(oNewTempDrawing, oContext, oOptions, oDataMedium)
	Catch
	End Try
	oNewTempDrawing.Close(True) 'True = Skip Save
Next
Wesley Crihfield
Message 7 of 21
vickimclJRCYT
@WCrihfield
Thanks for cleaning up the code and for your suggestions. As I mentioned, I pieced this together from 2 different sources and I'm slowly learning.
When running the rule now on multiple sheets, it saves just the first sheet as sheet 1, 2, 3, ...etc.. The sheet numbers are working nice now (thank you) but as you said, I need to figure out how to get all the sheets, not just the first one.
Victoria
Message 8 of 21
A.Acheson
@vickimclJRCYT  Is the task here to print to pdf each individual drawing sheet? If so the option would need to be change for each export as you loop through the collection.
Regards
Alan
Message 9 of 21
WCrihfield
In my last post, we are creating the new temporary drawing document within the loop, and using that in the export method, and are setting the oDataMedium.FileName within the loop, but the oContext and oOptions are being created and set outside the loop.  I wouldn't think that it would make any difference if we moved the oContext & oOptions creation & setting down inside the loop.  But I did just notice how the last two oOptions items were set, which should probably be commented out or deleted.  They are trying to use the variable iSheetNumber to set begin and end sheets in a custom sheet range, and that variable has not even been created yet or had a value set until down within the loop.  Then I would probably also change that other option from "PrintRangeEnum.kPrintSheetRange" to "PrintRangeEnum.kPrintCurrentSheet".
	oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet
I might also add in this line to ensure our copied sheet was the 'active' sheet, just after copying it over:
oOtherCopiedSheet.Activate
Wesley Crihfield
Message 10 of 21
vickimclJRCYT
@A.Acheson
Yes, exactly.
Message 11 of 21
vickimclJRCYT
@WCrihfield
Having a drawing with a part inserted only on the first sheet, when I run the code above, PDF's are saved out individually but I noticed the sheets were all labeled sheet 1 of 1, instead of sheet 1 of Total # of sheets like the idw.
I decided to cut some sections through the part and put those sections on different sheets, so there was something on all the drawings. After doing that and running the rule, I get the following error:
Man this ilogic stuff is tricky.
Message 12 of 21
A.Acheson
This rule works, the key thing here is to declare the sheet number as Integer as opposed to string or no declaration.
As string the export will loop on the first sheet.
Sub Main
'Define the drawing
	Print(iSheetNumber,oDrawing)
Next
End Sub
Sub Print (iSheetNumber As Integer, oDrawing As DrawingDocument)
'set PDF Options
	MessageBox.Show(iSheetNumber, "Title")
Else
	Exit Sub
	Try
	Catch
	End Try
End Sub
Regards
Alan
Message 13 of 21
WCrihfield
@A.Acheson & @vickimclJRCYT
I was referencing a couple of my older custom codes I did for someone else in the past, in which they wanted the sheet numbers to be 1 of 1 instead of 1 of # or sheets.  In that example I needed to create the other temporary drawing file and copy the sheets over to it.  In your case, since you want the sheet names to remain as they are, that other temporary drawing document and copying process is not needed.  I just did a couple of tests of my own to prove the point (with different code not putting iProperty values in file names).  The code worked as planned...each sheet was exported separately, and individually looked just as they do in the drawing.  The trick was in setting each sheet as 'active' at the start of the loop, then having that one option set to kPrintCurrentSheet.  Everything else is just everything else.  I obviously don't do this process everyday, because I always export all sheets to one multi-page PDF, and don't include iProperty stuff in the file names.
Just for reference though, here is the code I just tested with on my system.
Sub Main
	If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
		MsgBox("A Drawing Document must be active for this rule to work. Exiting.", vbCritical, "iLogic")
		Exit Sub
	Dim oDDoc As DrawingDocument = ThisApplication.ActiveDocument
	ExportAsPDF(oDDoc)
End Sub
Sub ExportAsPDF(oDrawDoc As DrawingDocument)
	'get the PDF Translator Add-in
	Dim oPDFAddin As TranslatorAddIn
	For Each oAddin As ApplicationAddIn In ThisApplication.ApplicationAddIns
		If oAddin.DisplayName = "Translator: PDF" Then
			oPDFAddin = oAddin
	Next
	'or
	'Dim oPDFAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	'Create the variables needed by the Translator Add-in
	oTO = ThisApplication.TransientObjects
	oContext = oTO.CreateTranslationContext
	oOptions = oTO.CreateNameValueMap
	oDataMedium = oTO.CreateDataMedium
	'get static parts of new file name (not sheet depentant)
	oPath = System.IO.Path.GetDirectoryName(oDrawDoc.FullFileName)
	oName = System.IO.Path.GetFileNameWithoutExtension(oDrawDoc.FullFileName)
	oDirChr = System.IO.Path.DirectorySeparatorChar
	'record originally 'active' sheet
	oOrigActiveSheet = oDrawDoc.ActiveSheet
	'<<<< Start loop for each sheet - file name includes sheet name >>>>
	For Each oSheet As Sheet In oDrawDoc.Sheets
		oSheet.Activate
		oSheetNumber = oSheet.Name.Split(":")(1) 'get the digit(s) after the ":"
		oNewFileName = oPath & oDirChr & oName & " Sheet " & oSheetNumber & ".pdf"
		'Check to see if the PDF already exists, if it does, ask if you want to overwrite it or not.
		If System.IO.File.Exists(oNewFileName) = True Then
			oAnswer = MsgBox("A PDF file with this name already exists." & vbCrLf &
			"Do you want to overwrite it with this new one?",vbYesNo + vbQuestion + vbDefaultButton2, "PDF ALREADY EXISTS")
			If oAnswer = vbNo Then Continue For
		oDataMedium.FileName = oNewFileName
		'The following If-Then statement defines the Options available, and their Values.
		If oPDFAddin.HasSaveCopyAsOptions(oDrawDoc, oContext, oOptions) Then
			oOptions.Value("Publish_All_Sheets") = 0 ' 0 = False, 1 = True
			oOptions.Value("Sheet_Range") = PrintRangeEnum.kPrintCurrentSheet
			oOptions.Value("Launch_Viewer") = 0 ' 0 = False, 1 = True
			oOptions.Value("All_Color_AS_Black") = 0 ' 0 = False, 1 = True
			oOptions.Value("Vector_Resolution") = 720 '150, 200, 400, 600, 720, 1200, 2400, 4800 ' DPI
			oOptions.Value("Remove_Line_Weights") = 0 ' 0 = False, 1 = True
		'Publish PDF
		oPDFAddin.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
	Next
	oOrigActiveSheet.Activate
End Sub
Wesley Crihfield
Message 14 of 21
vickimclJRCYT
@A.Acheson
Yes it's working! Ah I see what you did. I'm learning a lot from you guys.
 - Is there a way to have the dialog box only come up once for all sheets? Or is there no way around that?
Thank you,
Victoria
Message 15 of 21
vickimclJRCYT
@WCrihfield
This works too! And fast.
- I do like the dialog box though because we save to different folders depending on the job.
Thank you,
Victoria
Message 16 of 21
A.Acheson
No problem, I kind of stumbled across that error. If you type in the value it gets recognized as an integer straight away, I had another rule which had the declaration for integer so I was able to see what was missing, we are all learning.
The API Help doesn't have any document's on the PDF export other than the sample and some basics so that would be no help either.
You can just move the dialogue box to the start I believe.
Regards
Alan
Message 17 of 21
WCrihfield
If using @A.Acheson code, you would have to move the folder browser code either out into its own Function, or move it up into the Sub Main area.  Right now, since it is within the Print sub routine, and that whole sub routine is being called to run for each sheet, it will want to launch for each sheet.  If you moved it up into your Sub Main area, you would then want to pass that folder data to the Print sub routine, so it can use it.  To do that, you would have to add that extra 'input' variable to the definition line of that Print sub routine, then just use that same variable as you use in the definition line down within that sub routine.
  If you move it out into its own Function, then you could use something like a SharedVariable to store the value from one loop to the next, then check to see if it has a value before calling that Function to run again...something like this:
If String.IsNullOrEmpty(ExportPath) Then
	ExportPath = GetFolder()
that would prevent it from running when not needed.
Wesley Crihfield
Message 18 of 21
vickimclJRCYT
@WCrihfield
Sorry you lost me. This is getting complicated (for me)...not you guys.
Victoria
Message 19 of 21
vickimclJRCYT
@WCrihfield
Like this:
How do I declare the GetFolder ()  ?
Victoria
Message 20 of 21
WCrihfield
Sorry about that.  I've got so much stuff going around in my head, sometimes I just rattle off a bunch of stuff too quickly, without proper explanations.  I started with the last working code that @A.Acheson posted, then made one of the modifications to it that I mentioned.  See if this works for you as planned.
Sub Main
	'Define the drawing
	'select folder to export to (runs our custom Function)
	Dim ExportPath As String = SelectFolder
		'get sheet number
		Dim iSheetNumber As Integer = CInt(oSheet.Name.Split(":")(1))
		'run our custom Sub below to export the sheet to PDF
		Print(iSheetNumber, oDrawing, ExportPath)
	Next
End Sub
Function SelectFolder() As String
	Dim oFolder As String
		oFolder = Dialog.SelectedPath & "\"
	Return oFolder
End Function
Sub Print (iSheetNumber As Integer, oDrawing As DrawingDocument, ExportPath As String)
	'set PDF Options
		'MessageBox.Show(iSheetNumber, "Title")
	Try
	Catch
	End Try
End Sub
Wesley Crihfield
