Save Subassembly from iLogic in Master Level of Detail.
Hi All...
Used all day on this and it is driving me nuts 🙂
If I have a Main Assembly with a subassembly in it.
How can you have a iLogic go into the subassembly and change LOD to Master and save the file.
I can make it work with a custom LOD. But for some reason Master will not save.
Simple iLogic rule in Main assembly:
oAsembly = "C:\xxx\SubAssembly.iam"
doc = ThisApplication.Documents.Open(oAsembly,False)
auto = iLogicVb.Automation
auto.RunRule(doc, "MasterLOD")
Simple iLogic rule (MasterLOD) in SubAssembly :
oDoc = ThisDoc.Document
oDoc
.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations("Master").Activate oDoc.Save
Any idea what is wrong.
/Jacob
Curtis_Waguespack
Hi @Anonymous
Welcome to the forum.
You should be able to do all of this from the top level assembly, without opening the subassembly. First get the occurrence name, then get the document from the occurrence definition, then you can set the LOD...
I had to "smudge" the document with dirty = true to force it to save though.
I hope this helps.
Curtis
oOcc = Component.InventorComponent("SubAssembly:1")
Dim oDoc As Document
oDoc = oOcc.Definition.Document
oDoc.ComponentDefinition.RepresentationsManager.LevelOfDetailRepresentations("Master").Activate
oDoc.dirty = True
oDoc.save
.dirty = True was the trick 🙂
Thank you so much for that one.
/Jacob
