Save Part As from Drawing
Message 1 of 1
Hi all,
I have an iLogic rule here that that opens the model contained in a drawing, performs Save As on it and saves it in a predefined Revisions folder, and then closes it.
Everything is working correctly except that the drawing updates to referencing the newly created file.  I want to continue using the original part file, just saving a copy of the file into a sub folder.  I'm sure this is something simple that I'm missing but I'm at a loss.  Any help would be greatly appreciated.
'Define path that drawing is in.
oDrawingPath = ThisDoc.Path
'Define path that previous drawing revisions are in.
oDrawingRevPath = (ThisDoc.Path & "\" & "Old Revisions\")
'Define various data about the model contained in the drawing.
oModelFullFileName = ThisDrawing.ModelDocument.FullFileName
oModelName = IO.Path.GetFileName(omodelFullFileName)
oModelPath = IO.Path.GetDirectoryName(omodelFullFileName)
oModelNamec = IO.Path.GetFileNameWithoutExtension(oModelFullFileName)
'Opens part.  Change True to False to make part open in background.
openDoc = ThisApplication.Documents.Open(oModelFullFileName, True)
'Get revision number of part.
oModelRevNum = iProperties.Value("Project", "Revision Number")
'Save part as a new file in the revision folder with the revision number in the name.
openDoc.SaveAs(oDrawingRevPath & oModelNamec & " Rev " & oModelRevNum & ".ipt", False)
'Close the part.
openDoc.Close
InventorVb.DocumentUpdate()
*EDIT: Nevermind, I should have done about ten more minutes of investigation.  All I had to do was change this line:
To this:
openDoc.SaveAs(oDrawingRevPath & oModelNamec & " Rev " & oModelRevNum & ".ipt", True)
Replies (0)
