Message 1 of 1
Save IDW to DWG with iLogic on Forge
Hello, i'm trying to convert .idw files to .dwg within an assembly .iam.
This is my file structure
- Cubo.iam
- Cubo Parts (folder)
- Fondo.idw
- Fondo.ipt
- Piede.idw
- Piede.ipt
Inside Cubo.iam i created this iLogic script
FilesToConvert = New String() {"Fondo", "Piede"}
For Each FileToConvert In FilesToConvert
FullFilename = ThisDoc.Path & "\Cubo Parts\" & FileToConvert & ".idw"
Dim oDoc As DrawingDocument = ThisServer.Documents.Open(FullFilename, False)
oDoc.SaveAsInventorDWG(ThisDoc.Path & "\Cubo Parts\" & FileToConvert & ".dwg", True)
Next
I linked it with the trigger Property Change. When i change a parameter of the assembly on inventor all the dwgs are created perfectly.
But when i run the AddIn UpdateParametersPlugin from this tutorial it return this error
[11/16/2021 16:37:15] InventorCoreConsole.exe Information: 0 : Performing iLogic diagnostics...
[11/16/2021 16:37:15] InventorCoreConsole.exe Error: 0 : iLogic error
[11/16/2021 16:37:15] Context: RuleRunning
[11/16/2021 16:37:15] Details: System.NullReferenceException: Object reference not set to an instance of an object.
[11/16/2021 16:37:15] at ThisRule.Main()
[11/16/2021 16:37:15] at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
[11/16/2021 16:37:15] at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
[11/16/2021 16:37:15] InventorCoreConsole.exe Information: 0 : End of iLogic diagnostics...
The plugin works fine if i disable the iLogic script
