Save idw as dxf
Save idw as dxf
jmlip
Save idw as dxf
jmlip
I am very new to VB. I'm wondering if someone could explain what the invapp.CommandManager is or where I could find some help on it. The code is shown below. It works great but it saves the file as a zip file and I just need the dxf. Also, I don't understand how to tell it where the file should be saved.
Thanks you,
Joan
I downloaded an AutoSave program from one of the forums and I'm trying to customize it.
Sub AutoSave()
MsgBox "See you tomorrow", vbInformation
Dim invApp As Inventor.Application
Set invApp = ThisApplication
invApp.SilentOperation = True
Dim idwDoc As Inventor.DrawingDocument
Set idwDoc = invApp.ActiveDocument
Dim dxfFile As String
dxfFile = idwDoc.FullFileName
If dxfFile = "" Then
dxfFile = "c:\temp\" & idwDoc.DisplayName
Mid(dxfFile, Len(dxfFile) - 3) = ".dxf"
With invApp.CommandManager
Call .PostPrivateEvent(kFileNameEvent, dxfFile)
Call .StartCommand(kFileSaveCopyAsCommand)
End With
Set idwDoc = Nothing
invApp.SilentOperation = False
Set invApp = Nothing
End Sub
I am sure there is settings that can be made in VBA, but the easiest thing
to do might be to Open Inventor, and open a IDW. Click on File >>Save Copy
As and in that dialog select DXF then select Options. Uncheck Pack And go.
I believe it will remember that setting from then on.
A little less confusing method than using commandmanager IMO would be to
just use the idwDoc.Saveas command.
___________________
Kent Keller
www.kwikmcad.com
wrote in message news:5523259@discussion.autodesk.com...
be saved.
Thanks you,
Joan
customize it.
Sub AutoSave()
End With
End Sub
Kent's suggestion is a good one. Run the translator interactively and set
the settings the way you want. You can use the Document.SaveAs method to
create the dxf file. There was a previous limitation that forced people to
use the CommandManager, but that issue was resolved many realeases ago
(probably around Inventor 6 or 7). The thing that was changed is for the
SaveAs to use the extension of the filename to determine the type of file to
create. When you call the SaveAs method and supply a filename that has a
.dxf extension it will create a dxf file using the the settings saved in the
default .ini file for the dxf translator.
Brian Ekins
Autodesk Inventor API
"Kent Keller" wrote in message
news:5523303@discussion.autodesk.com...
___________________
Kent Keller
www.kwikmcad.com
jmlip
Thank you Kent and Brian. I really appreciate the help. I will give that a try.
Joan
jmlip
This is working well but I am still unclear on how to specify the folder where I want the dxf saved. I saved the ini file but the dxf is not saved in the folder I specified. How would I go about adding the path in the code?
Public Sub ExportToDXF()
Dim odoc As DrawingDocument
Set odoc = ThisApplication.ActiveDocument
Dim sFname As String
sFname = odoc.FullFileName
sFname = Left$(sFname, Len(sFname) - 3) & "dxf"
Call odoc.SaveAs(sFname, True)
End Sub
thank you very much!
Joan
