Save Flat File to specified directory
Lance127
Lance127
I am trying to use this code to take the flat pattern and save it to a specified directory ("X:\Burn Files\" ) but I can't get the path to work. I can save the file just fine but not where I would like it to go.
I'm a novice at VBA so any help would be appreciated.
Public Sub WriteSheetMetalDWG()
    ' Get the active document.  This assumes it is a part document.
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCompDef As SheetMetalComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
     If oCompDef.HasFlatPattern = False Then
        oCompDef.Unfold
    ' Build the string that defines the format of the DWG file.
    Dim sOut As String
    sOut = "FLAT PATTERN DWG?AcadVersion=2004&OuterProfileLayer=Burn&InteriorProfilesLayer=Burn&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN&SplineTolerance Double 0.01"
    ' Create the DXF file.
    ' oDataIO.WriteDataToFile sOut, "X:\Burn Files\"
' Get the filename minus the extension.
      Dim sFname As String
      sFname = oDoc.FullFileName
      sFname = Left(sFname, Len(sFname) - 4)
    ' The file format will depend on the extension
      sFname = sFname & "-B.dwg"
    'sFname = "X:\Burn Files\" & sFname
    oCompDef.DataIO.WriteDataToFile sOut, sFname
End Sub
Lance W.
Inventor Pro 2013 (PDS Ultimate)
Vault Pro 2013
Windows 7 64
Xeon 2.4 Ghz 12GB
skyngu
try this:
sFname = oDoc.displayname & ".dxf"
Autodesk Inventor Professional 2019
