Save Dialog Box
Save Dialog Box
Message 1 of 8
Save Dialog Box
When using the below VB Code:
Sub SetActiveDocument()
Dim inventorApp As Inventor.Application
Set inventorApp = GetObject(, "Inventor.Application")
Call inventorApp.Documents.Open("C:\KCI Vault\KCI Jobs\Automated Beam Clamp\Main Assembly\XXXXMBCA-500.iam", True)
Dim aDoc As Document
Set aDoc = inventorApp.ActiveDocument
aDoc.Update
aDoc.Save
End Sub
After I reach aDoc.Save I get a dialog box that asks if I want to save changes to "XXXXMBCA-500.iam" and its dependents?
Is there a way to turn this dialog box off or fill out the required info through VB??? so I can continue with code THANKS
Replies (7)
Message 2 of 8
Try using the SilentOperation property.
Something like this:
inventorApp.SilentOperation = True
aDoc.Save
inventorApp.SilentOperation = False
One other thing.  You don't need to use the
ActiveDocument property to set the document after you've opened.  The Open
method returns the document just opened.
aDoc =
InventorApp.Documents.Open("C:\Temp\Part1.ipt", True)
Brian
Ekins
Autodesk Inventor API Product Designer
href="http://blogs.autodesk.com/modthemachine">http://blogs.autodesk.com/modthemachine
When
using the below VB Code: Sub SetActiveDocument() Dim inventorApp As
Inventor.Application Set inventorApp = GetObject(, "Inventor.Application")
Clamp\Main Assembly\XXXXMBCA-500.iam", True) Dim aDoc As Document Set aDoc =
inventorApp.ActiveDocument aDoc.Update aDoc.Save End Sub After I reach
"XXXXMBCA-500.iam" and its dependents? Is there a way to turn this dialog box
THANKS
Message 3 of 8
That worked perfect thanks, and true I don't have to set aDoc as the active document, but I am testing code right now I am going to add to this. I have another question. If I have multiple files open is there a better way of setting one of those files to the active document other than using the Call inventorApp.Documents.Open("FILEPATHANDNAME") again to set it as the active document??
Again Thanks I am new to Inventor VB and I am struggling.
Message 4 of 8
Using the Open method probably isn't a bad way to
get what you want.  Here are a couple of other approaches.  If you
already have a reference to the document you want to activate you can do
this:
oDoc.Activate
If you don't have a reference and know it's open
you can do this:
oDoc =
Documents.Item("FILEPATHANDNAME")
oDoc.Activate
Brian Ekins
Message 5 of 8
Below is my modified code and the silent operation works wonderful. I am now having trouble with it updating. If I step through the code it has no problem but if I run the code the update doesn't happen. I also have to save the active workbook twice before it will do anything as well. Any Suggestions???
ActiveWorkbook.Save
ActiveWorkbook.Save
aDoc.Update
aDoc.Save
End Sub
Message 6 of 8
I think it should work.  Can you put together
a simple case that demonstrates the problem so I can understand your specific
case?
Brian Ekins
Message 7 of 8
What I do is open all models, and drawings associated with a particular spreadsheet. I then save the workbook, set the assembly as active in Inventor,update it and save it. Everything works when I step through the program using F8, but when I run the program the assembly still shows that it needs to be updated. I have a work around but its kinda of annoying. I put a message box right before I activate the assembly. It works fine with the message box, update is greyed out and the assembly is showing correctly. I tried delays and Doevents, but no luck the only thing that has worked is the annoying message box.
I don't know if this matters but I am running Inventor 08 and XP64 bit. If you still do not understand whats going on let me know and I will send you my models and spreadsheet. Its just weird that it doesn't update theres no errors in the code, plus it activates and saves. Just frustrating.
Message 8 of 8
I'll need an example to reproduce the
problem.  If you can trim the test case down as much as possible that will
help me a lot.  You can send it directly to me at
href="mailto:brian.ekins@autodesk.com">brian.ekins@autodesk.com
Brian Ekins
