Save As "TwinHex_SUB.ipt" not "Part 10 cannot be overwritten"?
andrew_canfield
andrew_canfield
Typo found
JelteDeJong
Multiple things are wrong here.
Try this for the sub SaveFile(...)
    Sub SaveFile(oDoc As Document, NewFileName As String)
        If (System.IO.File.Exists(NewFileName)) Then
            MsgBox(NewFileName & " already exists. cant save now...")
            Return
        Try
            oDoc.SaveAs(NewFileName, False)
        Catch ex As Exception
            MsgBox("Something went wrong while saving file: " & NewFileName)
        End Try
    End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
andrew_canfield
Thankyou - it has helped but I'm seeing odd glitches.
I will upload the test files because it's complicated (for me anyway), the idea is:
  1. ExcelSwap3 is a holding assembly with reads the file path (to be exported from a BoM if/when working)
  2. ReplaceX is the excel file holding the file paths & browser names
  3. Represent complicated sub-assemblies
  4. these have been created by the current code
  5. very odd but there should be two cones.
Overview: Replace.png
The 'Glitches' are these messages but the parts are still created?
Note the 3 bought out parts in the zipped up attachment have the End of Part marker pulled up to reduce the file size.
The Blocks are to represent small detailed parts (BoP's) possibly not required on a drawing at a 100:1 scale but the code replaces these with a bounding box (size setting in rule) - think it's better to see there's something there rather than omit them.
The same excel file can then be used to swap the 'Full Fat' sub assemblies with the 'Substitute' files without the need for a Level of Detail (hopefully this will help the processing as less files will be retrieved by the data management system).
The simplified sub assemblies appear like this - with blocks replacing the BoP's, Simplified.JPG
Any help appreciated - I've been chipping away at this for a while & think it's pretty close to working.
Regards
Andrew
