Save as new parts and assembly with ilogic rules
have a frame that does not have constant dimensions (the top will change and even the height will change according to the Form that I will create . As you see there are dimensions "DLO" , the number of DlOs will vary and also the height of them and also the width of the frame like frame generator I have a mullion that is an ilogic part that can be changed in height but the length is 10 mm .
so I like every time that opens this assembly the form ask about the dimension of the frame the the type of the mullion for each side of the frame and create some new parts with the base mullion but with different lengths according to the size of the frame.
As I dont want the base mullion changes, so I have to save all this new parts and also this assembly with new names.
Thank you,
Elmira
