Save and replace selection on BOM-Structure iLogic
Good morning!
I've been trying to get my head around this for a long time but can't get it to work. I've been trying to Save and Replace certain parts from my assembly which have the normal BOM-structure.
Dim oCommandMgr As CommandManager
oCommandMgr = ThisApplication.CommandManager
Dim oControlDef As ControlDefinition
oControlDef = oCommandMgr.ControlDefinitions.Item("AssemblyBonusTools_SaveAndReplaceComponentCmd")
Dim oDoc As Inventor.AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oSS As SelectSet
oSS = oDoc.SelectSet
Dim oAsmCompDef As InventorAssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oCompDef As Inventor.ComponentDefinition
oCompDef = oDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
oOcc = oAsmCompDef.ComponentOccurrence
For Each oOcc In oAsmCompDef
If ThisDoc.Document.BOMStructure = BOMStructureEnum.kNormalBOMStructure
		oSS.Clear
       oSS.Select(oOcc)
       oControlDef.Execute
	Next
Sergio.D.Suárez
Hi, try to execute the following ilogic rule from your assembly.
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oCD As AssemblyComponentDefinition = oDoc.ComponentDefinition
For Each oOcc As ComponentOccurrence In oCD.Occurrences
	If oOcc.Definition.BOMStructure = BOMStructureEnum.kNormalBOMStructure Then
	Dim refDoc As Document = oOcc.Definition.Document
	refDoc.Save
Next
 Note, this rule will read the structure of the file from the file properties, not from the bill of materials in the assembly file. To be clearer, a part may be to have a normal structure, but to be as a reference component in the assembly, this rule will then read the normal structure.
I hope this helps with your problem. Cheers
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thanks for your reaction!
This code just saves the parts with the BOM-structure tho. I need to Save and Replace the parts because I need to generate a INV-number and give the parts different dimensions.
I'm still not quite sure how to continue on this. Hopefully you can give me another tip.
Sergio.D.Suárez
Excuse me, I don't understand your question well.
Could you explain a little more? To see if we can help you. Cheers
Mechanical Designer
Started today with my mind fresh again and I got it to work on first try. My gratitude!
For people interested:
Dim oACD As AssemblyComponentDefinition = oDoc.ComponentDefinition
For Each oOcc  In oACD.Occurrences
oSS.Clear
        oSS.Select(oOcc)
        oControlDef.Execute
Next
My next problem is that there pop's up a message saying it's unable to properly terminate selection. I'm trying to save and replace all the strips( see picture). It didn't grab one from the part which is basicly the same.
