Save and replace parts in an assembly using iLogic
gcooper79
Message 1 of 31
gcooper79
I posted this in the wrong forum yesterday so reposting here hoping someone can help.
I've just started experimenting with ilogic and I would like to understand how to perform the following task.
I have a master assembly called PS07-01 and multiple parts in the assembly called PS07-01-01, PS07-01-02 etc..
I would like to save a version of the assembly as a different name e.g. PS07-02 and when I do, the associated parts would also save with a new name PS07-02-01, PS07-02-02 etc..
I have looked through the forum and the closest code I could find was the one below by @CurtisWaguespack .  However, this code only worked if I selected the parts, I would rather it was automated.
Any help would be gratefully appreciated.
Graeme
On Error Resume Next
oSelect = ThisDoc.Document.SelectSet.Item(1)
'catch an empty string in the imput
If Err.Number <> 0 Then
MessageBox.Show("Please select a component before running this rule.", "iLogic")
Return
' get a component by name.
Dim compOcc = Component.InventorComponent(oSelect.name)
'define document
oDoc = compOcc.Definition.Document
'create a file dialog box
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
'check file type and set dialog filter
If oDoc.DocumentType = kPartDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt"
Else If oDoc.DocumentType = kAssemblyDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam"
'set the directory to open the dialog at
oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
'set the file name string to use in the input box
oFileDlg.FileName = System.IO.Path.GetFileName(oDoc.FullFileName)
'work with an error created by the user backing out of the save
oFileDlg.CancelError = True
'specify the file dialog as a save dialog (rather than a open dialog)
oFileDlg.ShowSave()
MessageBox.Show("No File Saved.", "iLogic: Dialog Canceled")
ElseIf oFileDlg.FileName <> "" Then
MyFile = oFileDlg.FileName
'save the file
oDoc.SaveAs(MyFile, False) 'True = Save As Copy & False = Save As
Graeme
Replies (30)
Message 2 of 31
WCrihfield
Would you want to save the other copy of the main assembly and all of its parts to the same directory as the current one, or did you have some other scenario in mind?
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 31
gcooper79
I would like to open the master assembly (PS07-01) and save a copy with a new name Whilst directing inventor to the folder location of my choice.
once I save the copy (PS07-02), I would like the parts of the copied assembly to have new parts with filenames driven by the assembly. Edit* these parts should be saved in same location as the assembly file
I hope that makes sense.
Graeme
Graeme
Message 4 of 31
WCrihfield
Also, have you cosidered using Design Assistant or the "iLogic Design Copy" tool?
Below are a couple of links to help pages about these two standard tools.
To Copy Designs Containing iLogic Rules
To Rename, Copy, or Replace Files Using Design Assistant
Wesley Crihfield
Message 5 of 31
gcooper79
I did consider the design assistant but I want to try and make this as simple a task as possible for all my users as we will be copying the master assembly upwards of 15-20 times per contract.
If I can automate the task to copy and replace parts in the assembly by simply saving a copy of the assembly then that would be the desirable outcome.
graeme
Graeme
Message 6 of 31
WCrihfield
I'm heading home for the day, so I thought I would go ahead and post what I've got for you so far.
It still needs some String manipulation near the end to make sure I'm replacing the Occurrence with the right alternate one.  But this should get you pretty close.
Good luck.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Assembly Documents.",vbOK, "WRONG DOCUMENT TYPE")
	Return
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oFileDlg As FileDialog = Nothing
ThisApplication.CreateFileDialog(oFileDlg)
oFileDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
oFileDlg.FileName = IO.Path.GetFileName(oADoc.FullFileName)
oFileDlg.Title = "Specify New Name & Location For Copied Assembly"
oFileDlg.ShowDialog
	MsgBox("No File Saved.", vbOKOnly, "DIALOG CANCELED")
	oNewFileName = oFileDlg.FileName
	oADoc.SaveAs(oNewFileName, False)
oADoc = Nothing
InventorVb.DocumentUpdate()
oADoc = ThisApplication.ActiveDocument
For Each oRefDoc As Document In oADoc.AllReferencedDocuments
	Dim oEndDigits As String = Right(oRefDoc.FullFileName,2)
	oRefDoc.SaveAs(oADoc.FullFileName & oEndDigits, True)
Next
For Each oOcc As ComponentOccurrence In oADoc.ComponentDefinition.Occurrences
	Dim oOccDoc As Document = oOcc.Definition.Document
	Dim oOccFileName As String = oOccDoc.FullFileName
	Dim oOccPath As String = IO.Path.GetFullPath(oOccFileName)
	Dim oOccNewFileName As String = oOccDoc.FullFileName
	'oOcc.Replace(oOcc.N, True)
Next
I hope this helps.
If this solves your problem, or answers your questions, please click 'Accept As Solution".
Or, if this helps you reach your goal, please click 'LIKES" 👍.
Also, if you're interested, here are a few of the 'Ideas' I'd like to get implemented.
If you agree with any of them, please vote for them.
  • Add more capabilities to the 'Customize' dialog box (exe. Add Tab & Add Panel) Click Here
  • MessageBox, InputBox, and InputListBox Size & Format Options Click Here
  • Constrain & Dimension Images In Assembly Sketches & Drawing Sketches (TitleBlocks & SketchedSymbols) Click Here
  • Save Section View Status In DesignViewRepresentation (So It Can Be Used In The Drawing) Click Here
  • Add SolidBodies Folder In iLogic Rule Editor Model Tab Click Here
  • Convert All Views To Raster Before Autosave Stores To 'OldVersions' Folder Click Here
  • SetDesignViewRepresentation - Fix limitations for DrawingView of a Part Click Here
  • Create DocumentSubTypeEnum Click Here
Inventor 2020 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
Message 7 of 31
gcooper79
Thanks for taking the time to write the code.  I pasted it into my assembly but when I run the rule I get the error "Public member 'Title' on type 'FileDialog' not found."
I tried to comment out the line
 but then I get the Dialog Cancelled, no file saved.
Graeme
Graeme
Message 8 of 31
WCrihfield
Hi @gcooper79 .
It really wasn't finished yet, yesterday, but I did make a mistake when I defined FileDlg As 'FileDialog', instead of 'Inventor.FileDialog'.  A regular FileDialog is a member of System.Windows.Forms, and not the same as the one we want here (very tricky).
Try this version of the code, and let me know if it works for you.
	Return
oFileDlg.FileName = IO.Path.GetFileName(oADoc.FullFileName).TrimEnd("."c,"i"c,"a"c,"m"c)
oFileDlg.DialogTitle = "Specify New Name & Location For Copied Assembly"
oFileDlg.ShowSave
oADoc = Nothing
Dim oLast3Chars As String
	oLast3Chars = Left(Right(oRefDoc.FullFileName,7),3)
	oRefDoc.SaveAs(oADoc.FullFileName & oLast3Chars, True)
Next
	oOccDoc = oOcc.Definition.Document
	oLast3Chars = Left(Right(oOccDoc.FullFileName,7),3)
	oOccNewFileName = Left(oADoc.FullFileName,Len(oADoc.FullFileName)-4) & oLast3Chars
	oOcc.Replace(oOccNewFileName, True)
Next
I hope this helps.
Wesley Crihfield
Message 9 of 31
gcooper79
Hi @WCrihfield
Thanks for the updated code, I pasted and ran the rule.   The dialog box now appears and I can save the assembly, however, no new instances of the parts are created.
I have attached the assembly for your information in case there's some information that I may have omitted that is causing this issue.
Graeme
Graeme
Message 10 of 31
WCrihfield
We probably just need to Open each RefDoc (invisibly in the background), before saving it off, then Close it.
We can try that to see if it works.
I added a line just under the AllReferencedDocuments Loop that opens each one in the background.
And another line at the end of it which closes each one.
	Return
oFileDlg.ShowSave
oADoc = Nothing
	ThisApplication.Documents.Open(oRefDoc.FullFileName,False)
	oRefDoc.Close
Next
Next
Wesley Crihfield
Message 11 of 31
WCrihfield
After the last update i opened your files (had to delete a few linked references it couldn't find), but saw that the code still needed another tweak to get it working right.  So I added document type check in there, then included the string for the file extension, which was still missing before.  I got this version to work on my PC.
	Return
oFileDlg.ShowSave
oADoc = Nothing
	oLast3Chars = Left(Right(oRefDoc.FullFileName, 7), 3)
	If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		oRefDoc.SaveAs(Left(oADoc.FullFileName, Len(oADoc.FullFileName) -4) & oLast3Chars & ".ipt", True)
	ElseIf oRefDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		oRefDoc.SaveAs(Left(oADoc.FullFileName, Len(oADoc.FullFileName) -4) & oLast3Chars & ".iam", True)
	oRefDoc.Close
Next
	oLast3Chars = Left(Right(oOccDoc.FullFileName, 7), 3)
	If oOccDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		oOccNewFileName = Left(oADoc.FullFileName,Len(oADoc.FullFileName)-4) & oLast3Chars & ".ipt"
	ElseIf oOccDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		oOccNewFileName = Left(oADoc.FullFileName,Len(oADoc.FullFileName)-4) & oLast3Chars & ".iam"
Next
Wesley Crihfield
Message 12 of 31
gcooper79
@WCrihfield
Definitely getting closer.  When I run the rule now I get copies of the part files but they are not replacing the originals in the new assembly.
Graeme
Message 13 of 31
WCrihfield
I edited & updated my last post maybe 10-15 minutes after posting it, because I saw that I needed to repeat the DocumentType check & extension string process in the Replace section of the code.  That seemed to fix the Replace section of the code for me.
Did the code you ran have those two updates in it, when you tried it.
Wesley Crihfield
Message 14 of 31
gcooper79
Hi @WCrihfield
That worked.  I can now save a copy of the file and the parts update accordingly.
Thank you for your help with this.
Graeme
Graeme
Message 15 of 31
WCrihfield
Glad to hear it. Your welcome.
I love this forum.  We get to learn and figure out new stuff every day, while helping other out.
While exploring to figure out problems, you end up finding something new you can use for something else, along the way.
Wesley Crihfield
Message 16 of 31
gcooper79
Hi @WCrihfield
To build on what you have already created.  How would I alter the code so it only created copies of part files and not content center files?
Would we have to modify this if statement
with something like
If oOccDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject +  oOccDoc.path = thisDoc.path Then
Graeme
Graeme
Message 17 of 31
WCrihfield
Nope. You have to get ite PartComponentDefinition, first. Then you can check "IsContentMember" boolean.
Here's the updated code.  I didn't put in any alternative action to take, if it IS a content member.  I just set it up to not process the item if it IS a content member.
	Return
oFileDlg.ShowSave
oADoc = Nothing
		Dim oRefPDoc As PartDocument = oRefDoc
		Dim oRefPDef As PartComponentDefinition = oRefPDoc.ComponentDefinition
		If oRefPDef.IsContentMember = False Then
	oRefDoc.Close
Next
		Dim oOccPDef As PartComponentDefinition = oOcc.Definition
		If oOccPDef.IsContentMember = False Then
			oOccNewFileName = Left(oADoc.FullFileName, Len(oADoc.FullFileName) -4) & oLast3Chars & ".ipt"
Next
Wesley Crihfield
Message 18 of 31
gcooper79
Hi @WCrihfield
I updated the code and whilst the first section works i.e. it doesn't copy and rename the content center parts, the second section of the code replaces all content center parts with the last part copied.
Graeme
Message 19 of 31
gcooper79
HI @WCrihfield ,
I had a look through your code and noticed there were a couple of differences between the save batch of code and the replace batch of code.
The first line was missing and the second line had definition instead of ComponentDefinition.
  It seems to had fixed the problem.
Thanks again for your help with this coding.
Graeme
Graeme
Message 20 of 31
Thank you so much for the information provided above. I am trying to achieve the same outcome where I have a master assembly and want to do a save as, and rename the new assembly and have the parts be renamed as well so I can change lengths without affecting the master assembly parts. However, after I pasted the latest rule logic code and clicked save and run, I get a large error message. (in attachment) Any suggestion on resolving the issue would be greatly appreciated!
@WCrihfield
